Hello everyone,
I am trying to write a new controller as simply as possible and get it working with Gazebo, but now that I have everything set up, my new controller does not seem to register with controller_manager. I am new to ROS, ros_control, and cmake, so I am struggling to troubleshoot.
When launching my controller, parameters load successfully, but I receive an error for each controller:
Could not load controller 'joint1_position_controller' because controller type 'artbot_control_new/CustomController' does not exist.
What is necessary for controller_manager to recognize the new class? In my workspace I have:
  1. Robot description and gazebo packages for a robot very similar to this tutorial. Works correctly with existing ros_controllers examples.
  2. A control package with the following:
  • CMakeLists.txt and package.xml files specifying controller_interface, hardware_interface, pluginlib.
  • In src, a controller class .cpp file based on this example, with the namespace, class name, and pluginlib arguments updated.
  • A .yaml config file and launchfile specifying this package and the new controller.
I could be missing something very basic, but I am not sure where to look next. Let me know what information I can provide.
I'm using ROS Indigo on Ubuntu 14.04.
Thanks in advance!
Originally posted by ColinG on ROS Answers with karma: 68 on 2015-04-23
Did you add an export section to your pkg manifest? Something like (from position_controllers/package.xml):
<package>
  <export>
    <controller_interface plugin="${prefix}/artbot_control_plugins.xml"/>
  </export>
</package>
Without that export, your package will not be considered a package providing a controller plugin, which is what the manager will look for.
See also wiki/pluginlib - Registering Plugin with ROS Package System.
Originally posted by gvdhoorn with karma: 86574 on 2015-04-24
Comment by ColinG on 2015-04-24:
This is exactly what I was missing! The controller is functioning now as expected. Thank you for pointing me in the right direction.
