Im trying to setup my nav config to use pose_follower as my local planner (so i can have backwards movements) and then reading around, people say NavFn doesnt work with pose_follower. So i read around and saw people where saying to use sbpl_lattice_planner with pose_follower, so i tried to add it as a plugin to use with move base. For some reason im getting a really wierd error when i launch move_base (the full log can be viewed in a pastebin i made to not clutter the question. But the primary part of the error log is this:
process[move_base-1]: started with pid [9692]
[ WARN] [1428337418.710189086, 9.812000000]: Waiting on transform from base_link to odom to become available before running costmap, tf error:
[ INFO] [1428337418.724891841, 9.826000000]: Loading from pre-hydro parameter style
[ INFO] [1428337418.777851298, 9.878000000]: Using plugin "obstacle_layer"
[ INFO] [1428337418.840831680, 9.939000000]:     Subscribed to Topics:
[ INFO] [1428337418.889993790, 9.989000000]: Using plugin "inflation_layer"
[ INFO] [1428337419.030963854, 10.131000000]: Name is SBPLLatticePlanner
terminate called after throwing an instance of 'SBPL_Exception*'
[move_base-1] process has died [pid 9692, exit code -6, cmd /opt/ros/indigo/lib/move_base/move_base /odom:=/odometry/filtered __name:=move_base __log:=/home/parallels/.ros/log/3216eba8-dc79-11e4-9dbf-001c42dabd93/move_base-1.log].
[move_base-1] restarting process
I did the following to install/use sbpl_lattice planner as a plugin:
sudo apt-get install ros-indigo-sbpl
As when i install sbpl from source, it installs the files into /usr/local (i think i might be doing something wrong) and then therefore when i clone the sbpl_lattice_planner source and compile it via catkin_make it cant properly link the libspl shared libraries because its looking for it in /opt/ros/share/sbpl instead.
So after i install the sbpl ros debian, I clone the sbpl_lattice_planner source into my workspace, and compile successfully.
Then rospack plugins --attrib=plugin nav_core shows sbpl_lattice_planner is loaded as a plugin, and inside the bgp_plugin.xml i find that
<class name="SBPLLatticePlanner" type="sbpl_lattice_planner::SBPLLatticePlanner"...
So i use SBPLLatticePlanner as the name for the move_base parameter base_global_plannerto look like so:
<launch>
  <master auto="start"/>
  <node pkg="move_base" type="move_base" respawn="true" name="move_base" output="screen">
    <remap from="/odom" to="/odometry/filtered" />
    <param name="base_local_planner" value="pose_follower/PoseFollower"/>
    <param name="base_global_planner" value="SBPLLatticePlanner"/>
    <param name="SBPLLatticePlanner/primitive_filename" value="$(find sbpl)/matlab/mprim/pr2.mprim" />
    <param name="controller_frequency" value="10.0"/>
    <rosparam file="$(find test_2dnav)/costmap_common_params.yaml" command="load" ns="global_costmap" />
    <rosparam file="$(find test_2dnav)/costmap_common_params.yaml" command="load" ns="local_costmap" />
    <rosparam file="$(find test_2dnav)/local_costmap_params.yaml" command="load" />
    <rosparam file="$(find test_2dnav)/global_costmap_params.yaml" command="load" />
#    <rosparam file="$(find test_2dnav)/base_local_planner_params.yaml" command="load" />
    <rosparam file="$(find test_2dnav)/pose_follower_params.yaml" command="load" />
  </node>
</launch>
Would anyone happen to know if im missing something/mis-configuring something? I know you must load a primitives file (which was the first issue i overcame).
Originally posted by l0g1x on ROS Answers with karma: 1526 on 2015-04-06
Thanks to @balamesh I figured out how to get sbpl_lattice_planner running on indigo. Seems like there where some missing symbols on initialization of sbpl_lattice_planner when loading it into move_base as a global planner plugin.
You can view a working version for indigo here: https://github.com/MASKOR/maskor_navigation
Make sure you use both the sbpl and sbpl_lattice_planner from source from that repo, as the normal sbpl does not link libraries correctly for sbpl_lattice_planner use
Originally posted by l0g1x with karma: 1526 on 2015-04-07
