hello,
I'm using Ubuntu 14.04 and ROS Indigo
I used the following block of code to publish the transformation of base_link frame and odom frame:
geometry_msgs::TransformStamped odom_trans;
    odom_trans.header.stamp = current_time;
    odom_trans.header.frame_id = "odom";
    odom_trans.child_frame_id = "base_link";
    odom_trans.transform.translation.x = x;
    odom_trans.transform.translation.y = y;
    odom_trans.transform.translation.z = 0.0;
    odom_trans.transform.rotation = odom_quat;
    //send the transform
    odom_broadcaster.sendTransform(odom_trans);
Also, I used this launch file to publish the other frames:
<launch>
<node pkg="tf" type="static_transform_publisher" name="link1_broadcaster" args="0 0 1 0 0 0 1 base_link camera_link 100" />
</launch>
When the robot start moving I run rviz and it shows the odom frame moving, but the base_link and camera_link are fixed in their initial position. I think I missed something but I don't know what is it.
UPDATE:
  1. current_time is set inside the loop while(nodehandle.ok()) and is set to current_time = ros::Time::now();
  2. odom_broadcaster is created outside the loop and at the beginning of the main as tf::TransformBroadcaster odom_broadcaster;
  3. This is running live
  4. When I run rosrun tf tf_echo odom base_link it shows values like:
    At time 1428335473.731
    • Translation: [-0.338, 1.148, 0.000]
    • Rotation: in Quaternion [0.000, 0.000, 0.295, 0.955] in RPY [0.000, -0.000, 0.600] At time 1428335474.787
    • Translation: [-1.613, 3.059, 0.000]
    • Rotation: in Quaternion [0.000, 0.000, 0.223, 0.975] in RPY [0.000, -0.000, 0.449]
  5. This is my tf tree:
tf tree
Also I have this transformation in the launch file: <node pkg="tf" type="static_transform_publisher" name="link1_broadcaster" args="0 0 1 0 0 0 1 base_link camera_link 100" />
Originally posted by nouf on ROS Answers with karma: 71 on 2015-04-05
Comment by Tom Moore on 2015-04-06:
When do you set the current_time variable, and with what value? Also, where are you creating odom_broadcaster? Are you running this live or against a bag file? What happens if you run rosrun tf tf_echo odom base_link?
Comment by nouf on 2015-04-06:
please find the update in the question
Comment by l0g1x on 2015-04-06:
what does roswtf tell you?
Wait, are you expecting odom and base_link to move with one another? odom is a world-fixed frame, and base_link is attached to the robot. As your robot moves through the world, they will not remain "with" one another in rviz.
Did you solve? Be sure in your code to update all frames with the most recent time stamp. I mean, every loop you should be sure that the broadcast information is updated:
odom_trans.header.stamp = ros::Time::now();
From the tutorial you see that that line of code is inside a loop. maybe you forgot to update all the frames for the camera and so on... I hope I helped you.
Regards
Originally posted by Andromeda with karma: 893 on 2015-04-25
