Hello ALL
I have this strange problem that I encountered while trying to write new plugin. I followed the rqt plugin tutorial and I am able to build. But when starting rqt I can see plugin in Visualization menu. When I click I get this message
[ERROR] [1427841427.537909362]: Failed to load nodelet [gps_plot/GPSPlot_1] of type [gps_plot/GPSPlot]: Failed to load library /home/rob/projects/Test/devel/lib//libgps_plot.so. Make sure that you are calling the PLUGINLIB_EXPORT_CLASS macro in the library code, and that names are consistent between this macro and your XML. Error string: Could not load library (Poco exception = /home/rob/projects/Test/devel/lib//libgps_plot.so: undefined symbol: _ZTVN8gps_plot9GPSPluginE)
RosPluginlibPluginProvider::load_explicit_type(gps_plot/GPSPlot) failed creating instance
PluginManager._load_plugin() could not load plugin "gps_plot/GPSPlot": RosPluginlibPluginProvider.load() could not load plugin "gps_plot/GPSPlot"
To get started I get one h and one cpp file. For now I commented out all Qt widget_ and ui_ to just build.
Also
ldd /home/rob/projects/Test/devel/lib//libgps_plot.so
does not show any missing libs
From above error I try to grep for strings
~/projects/Test/devel/lib$ strings libgps_plot.so  | grep _ZTVN8gps_plot9GPSPluginE
nm -u libgps_plot.so  | grep _ZTVN8gps_plot9GPSPluginE
U _ZTVN8gps_plot9GPSPluginE
So it is there
c++filt _ZTVN8gps_plot9GPSPluginE shows
vtable for gps_plot::GPSPlugin
I also made sure that I export class at bottom of cpp file
PLUGINLIB_EXPORT_CLASS(gps_plot::GPSPlugin, rqt_gui_cpp::Plugin)
So I am little puzzled by this. Any one knows or had this? I am thinking something is missing in my CMakeList file.
Also in above error there is double "//"before libgps_plot.so. Not sure how to fix this. I dod go over my plugin.xml and package.xml and CMakeLists.txt file over and over and I do not see anything odd.
Here is my CMakeLists.txt
project(gps_plot)
    dynamic_reconfigure
    message_generation
    roscpp
    rqt_gui
    rqt_gui_cpp
    sensor_msgs
    std_msgs
find_package(Boost REQUIRED COMPONENTS
    program_options
find_package(Qt4 REQUIRED COMPONENTS
    QtCore
    QtGui
include(${QT_USE_FILE})
set(gps_plot_SRCS
  src/gpsPlugin.cpp
set(gps_plot_HDRS
  include/gps_plot/gpsPlugin.h
catkin_package(
  INCLUDE_DIRS  ${gps_plot_INCLUDE_DIRECTORIES}
  LIBRARIES     ${PROJECT_NAME}
  CATKIN_DEPENDS dynamic_reconfigure message_generation roscpp rqt_gui rqt_gui_cpp sensor_msgs std_msgs
qt4_wrap_ui(
    gps_plot_UIS_H
    ${gps_plot_UIS}
include_directories(
    ${Boost_INCLUDE_DIRS}
link_directories(
    ${Boost_LIBRARY_DIRS}i
    include
    ${catkin_INCLUDE_DIRS}
add_library(
    ${PROJECT_NAME}
    ${gps_plot_SRCS}
target_link_libraries(
   ${PROJECT_NAME}
   ${catkin_LIBRARIES}
   ${QT_QTCORE_LIBRARY}
   ${QT_QTGUI_LIBRARY}
   ${Boost_LIBRARIES}
find_package(class_loader)
class_loader_hide_library_symbols(${PROJECT_NAME})
install(FILES plugin.xml
  DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
install(TARGETS ${PROJECT_NAME}
    ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
    LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
    RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
install(DIRECTORY include/${PROJECT_NAME}/
    DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
And my plugin.xml
<library path="lib/libgps_plot">
  <class name="Btest/GPSPlot" type="gps_plot::GPSPlugin" base_class_type="rqt_gui_cpp::Plugin">
    <description>
      Test GPS plotter using nmea_msgs/Sentence and sensor_msgs/NavSatFix messages
    </description>
    <qtgui>
      <group>
        <label>Visualization</label>
        <icon type="theme">folder</icon>
        <statustip>Plugins related to visualization.</statustip>
      </group>
      <label>Test GPS plotter</label>
      <icon type="theme">applications-internet</icon>
      <statustip>Test GPS and status points on an map</statustip>
    </qtgui>
  </class>
</library>
Originally posted by oxoocoffee on ROS Answers with karma: 61 on 2015-03-31
Post score: 4
3 Answers 3
The symbol is listed by nm, but as a U which means undefined:
https://sourceware.org/binutils/docs/binutils/nm.html
You probably declared the class, but for some reason did not define the class, there for your shared library will be looking for the definition of the class, usually resulting in a T from nm, from another library at link time. This error has likely eluded you because the default behavior for shared libraries on Linux when a symbol is missing at compile time is to assume it is provided at runtime. At runtime the symbol is not there, which is why you have your error.
You can try using the --no-allow-shlib-undefined linker flag to find it at compile time, but you can also just look at your source code and try to figure out the issue. If you post your package on GitHub (or something similar) we can look at it in more detail. Either way, this is likely a C++ problem.
Originally posted by William with karma: 17335 on 2015-04-01
Comment by AndyZe on 2020-06-07:
As of Melodic, I had to use this instead of --no-allow-shlib-undefined. Thanks for putting me on the right path, though.
-Wl,--no-undefined
Looks like rqt - Writing a C++ Plugin is little incomplete. Since I did commented out all instances of QT ( Ui::MyPluginWidget ui_; QWidget* widget_; ) BUT LEFT Q_OBJECT in MyPlugin class this was the source of the problem. I am intending to update above link in couple of days and clean it up with my finding/corrections/notes. Also will try to add missing C++ UI writeup
Originally posted by oxoocoffee with karma: 61 on 2015-04-01
Comment by William on 2015-04-01:
Can you expand on why you feel it is incomplete. It's not clear from your answer what exactly is wrong. Please update your answer with changes you make to the wiki.
I had this error then found that my qt4_wrap_cpp() was wrapping my cpp file, and not the header, fixed it and the plugin loaded properly. There isn't a qt4_wrap_cpp above, try adding it- it should wrap any headers that have Q_OBJECT in them.
I made a complete C++ rqt example following the tutorial https://github.com/lucasw/rqt_mypkg/tree/master/rqt_example_cpp
