Hi to all,
I try to move a box in my planning scene using a tf-frame. But it's not working at the moment.
I insert the box as shown in the moveit-tutorial and giving it a tf-frame additionally like this:
 /* The id of the object is used to identify it. */
  co_box.id = "box1";
  co_box.header.frame_id = "//box_frame";
If I now insert the box, it is correctly inserted at the position and orientation I publish in my tf-broadcaster. But when I move the frame in the broadcaster, I can see the frame moving in Rviz but not the box.
What can I do here. Is the box not correctly linked to the tf-frame or do I constantly need to update the planning scene. I'm really stuck here. I would really appreciate if somebody could help me out.
Edit (the code for inserting the box and trying to move):
 // insert BOX
  moveit_msgs::CollisionObject co_box;
  co_box.id = "box1";
  // co_box.header.frame_id = "box_frame";
  /* Define a box to add to the world. */
  shape_msgs::SolidPrimitive primitive;
  primitive.type = primitive.BOX;
  primitive.dimensions.resize(3);
  primitive.dimensions[0] = 1.0;
  primitive.dimensions[1] = 0.2;
  primitive.dimensions[2] = 0.4;
  /* A pose for the box (specified relative to frame_id) */
  geometry_msgs::Pose box_pose;
  box_pose.orientation.w = 1.0;
  box_pose.position.x =  0.0;
  box_pose.position.y =  0.0;
  box_pose.position.z =  0.0;
  co_box.primitives.push_back(primitive);
  co_box.primitive_poses.push_back(box_pose);
  co_box.operation = co_box.ADD;
  std::vector<moveit_msgs::CollisionObject> collision_objects;
  collision_objects.push_back(co_box);
  ROS_INFO("Add collision objects into the world");
  planning_scene_interface.addCollisionObjects(collision_objects);
  /* Sleep so we have time to see the object in RViz */
  sleep(10.0);
  while(ros::ok()){
       co_box.operation = co_box.MOVE;
       sleeprate.sleep();
Originally posted by bluefish on ROS Answers with karma: 236 on 2015-03-30
If you put it into the planning scene, it's stored there in the planning frame for planning, so if it is moved, you need to update it. Use the MOVE operation in CollisionObject to only supply a new pose without resending geometry all the time.
Originally posted by dornhege with karma: 31395 on 2015-05-06
Comment by bluefish on 2015-05-07:
Hi! Thanks for your answer! I tried co_box.operation = co_box.MOVE; constantly called in a while-loop but it doesn't seem to work. Do have to add an planning_scene_interface-command? Something like planning_scene.update? But I can't find an appropriate one...
Comment by dornhege on 2015-05-07:
What are you sending?
as I wrote above: I send co_box.operation = co_box.MOVE;
Or do you mean how I send the whole collision_object to the planning scene? This I do pretty much exactly as explained in the moveit c++-tutorial.
There are two ways: As part of a planning scene update or directly as an object. I have only tried the planning scene update, although I assume that both should have the same functionality.
I updated the question with the complete code for inserting the box and the try to move it. Could you tell what code excatly I have to add? (What was your code for updating the planning scene?)
I haven't worked with the planning scene interface. I send these directly as a planning scene message. However, I believe it should work. I have also used the MOVE operation in there.
Hmm. But I tried it and cannot see any movement... As before the tf-frame is moving but not the object... :(
@dornhege: could you maybe post the code snippet of inserting and moving objects via planning scene messages? Would really appreciate!
Hi!
Finally I managed to solve this issue. If anybody is facing the same problem, here is my approach, which works for me:
ros::Publisher collision_object_publisher = node_handle.advertise<moveit_msgs::CollisionObject>("collision_object", 1);
  while(collision_object_publisher.getNumSubscribers() < 1)
      ros::WallDuration sleep_t(0.5);
      sleep_t.sleep();
  moveit_msgs::CollisionObject co;
  co.header.frame_id = "box_frame";
  co.id = "box";
  geometry_msgs::Pose pose;
  // pose.orientation.w = 1.0;
  primitive.dimensions[0] = 0.1;
  primitive.dimensions[1] = 0.1;
  primitive.dimensions[2] = 0.1;
  co.primitives.push_back(primitive);
  co.primitive_poses.push_back(pose);
  co.operation = co.ADD;
  collision_object_publisher.publish(co);
  sleep(5);
  moveit_msgs::CollisionObject move_object;
  move_object.id = "box";
  move_object.header.frame_id = "box_frame";
  move_object.primitive_poses.push_back(pose);
  move_object.operation = move_object.MOVE;
  ros::Rate loop_rate(100);
  while(ros::ok()){
    collision_object_publisher.publish(move_object);
    loop_rate.sleep();
    ROS_INFO("Another loop");
Thanks @dornhege for the hints!!
Originally posted by bluefish with karma: 236 on 2015-05-26
