Now I have a turtlebot 2, and I want to build a map. As gmapping needs odometry, so I think it would have a better result than hector_mapping. As RPLidar has 360 degree while kinect has only 57 degree, so while gmapping, I think RPLidar would has a better result.
However, to my disappointment, the map builded by RPLidar is too bad!
I found that the map builded by rplidar + hector_mapping is really good.
But I really want to know why RPLidar + gmapping could not have a good result, does anyone know this?
Thank you !!
My bagfile.
Originally posted by tanghz on ROS Answers with karma: 130 on 2015-03-29
Comment by afranceson on 2015-03-29:
I have the same problem. I'm working to some tests about this, maybe can be useful for you too:
Localization problem with gmapping and RPLidar
Comment by tanghz on 2015-03-29:
Thank you very much!!
Comment by tanghz on 2015-04-01:
Wow!!!! You are so great!!! Thank you, thank you so much!!!
Comment by afranceson on 2015-04-02:
Glad to have been helpful!
Comment by tanghz on 2015-04-02:
Thank you for taking the time to give me a hand. Now I have uploaded the RVIZ picture, in the picture,the red or green lines or points are the laser scan data. I increased the size of the laser size.
Now compared with yours, I think the only difference is the tf transform, let me try again. thanks!
I am sorry to have kept you waiting so long. I am a newer to ROS, and I have just learned how to use the rosbag. I upload the bagfile to my network disk. The bagfile
I am sorry that I used a Chinese skydrive. To download the bagfile, click the 下载(4.4M) .
Comment by zl3612 on 2016-06-02:
Hey Tang, Could you please teach with using rplidar and hector together?
Comment by tanghz on 2016-07-18:
I am sorry that I see your question until now, and have you solved your question?
