Hi,
I want to know which package I can use to teleoperate with a keyboard the stageros? because in the tutorial
http://wiki.ros.org/stage/Tutorials/SimulatingOneRobot
they told you to use teleop_base which is depracted and it is for the stacks
http://answers.ros.org/question/9207/teleop_base-deprecated-need-generic-teleop-package/#
and the other versions around are for the stacks and not for catkin
http://answers.ros.org/question/54078/stage-simulatingonerobot-tutorial-is-there-still-a-teleop_base-package/
I also wonder if the packages that are based on the stacks can be used with catkin? and I can do the following:
http://answers.ros.org/question/115261/how-to-install-an-individual-package-in-ros-hydro/
Best,
Originally posted by andrestoga on ROS Answers with karma: 188 on 2015-03-28
Use teleop_twist_keyboard on Hydro.
Originally posted by ahendrix with karma: 47576 on 2015-03-28
Comment by ahendrix on 2015-03-28:
I've also opened a ticket indicating that the tutorial you're using needs to be updated: https://github.com/rtv/Stage/issues/50
