Hi!
I added an object into the world and attached it to the robot as described in this moveit-tutorial. As in the tutorial stated I attached the object with this piece of code:
ROS_INFO("Add an object into the world");
planning_scene_interface.addCollisionObjects(collision_objects);
sleep(5.0)
group.attachObject(co.id)
This all works fine, but while moving the robot with the attached object, collisions of this attached object and other objects in the environment are not detected. In fact, the object seems not attached while the robot is moving. It just pops up again at the target pose.
Anybody knows how a collision check can be achieved? (The attached object should be handled as part of the robot after being attached)
Thanks and regards
Originally posted by bluefish on ROS Answers with karma: 236 on 2015-03-23
Comment by bluefish on 2015-04-23:
Anybody an idea how to achieve it? I also tried the publisher from this tutorial. But there I have the same problem...
Okay, I think I found an answer myself now. When attaching the object, I only tried it without the real robot, until now. There, no collision at all was recognized between the attached object and the surrounding as stated above.
Since today I can test it with the real robot and there it seems to work perfectly. Without the real robot the ee_link was not published sufficiently and therefore the attachment did not work properly. At least this is my guess.
So in the end, the piece of code I posted above and which I took from the tutorial works perfectly fine.
Originally posted by bluefish with karma: 236 on 2015-04-28
