Hello ROS community,
I'm working on a project which goal is to create an autonomous mobile robot running SLAM algorithm using gmapping. I'm using odometry from motors encoder and laser scan data from RPLidar. ROS Hydro is running on a UDOO board.
I complete the navigation stack setup and, as soon the robot is not moving, all seems to work fine (transformations published, map published, laser scan data published). When I move the robot using teleop the map->odom transformation broadcasted by gmapping seems to make no-sense. Better than other words is a video of RViz.
Apart the localization problem I cannot understand why the odom and base_link frame are not overlapped after start. They don't should be?
Here the transformations tree: The transformations tree
Here the nodes and topics: The nodes and topics
This the gmapping node configuration:
throttle_scans: 1
base_frame: base_link
map_frame: map
odom_frame: odom
map_update_interval: 10
maxUrange: 5.5
maxRange: 6
sigma: 0.05
kernelSize: 1
lstep: 0.05
astep: 0.05
iterations: 5
lsigma: 0.075
ogain: 3.0
lskip: 0
minimumScore: 0.0
srr: 0.1
srt: 0.2
str: 0.1
stt: 0.2
linearUpdate: 1.0
angularUpdate: 0.5
temporalUpdate: -1.0
resampleThreshold: 0.5
particles: 30
xmin: -10
xmax: 10
ymin: -10
ymax: 10
delta: 0.05
llsamplerange: 0.01
llsamplestep: 0.01
asamplerange: 0.005
lasamplestep: 0.005
transform_publish_period: 0.1
occ_thresh: 0.25
I will really appreciate any suggestion to fix my problem. I did not publish other configurations since the problem seems to be related to gmapping: if other informations are needed I will be happy to provide them.
Many thanks! Ale
UPDATE
As suggested by paulbovbel I follow the guide test odometer quality. The result is quite good for straight path, a little bit less for rotation.
Watching the video I think the problem could not be in odometry: in the video the first seconds (until time 0:08) after robot starts moving all seems to be fine. During this time the position is updated based on odometry only (at least... I guess!) and laser scan data (in red) match the map: this means that odometer data is quite good. After 0:08 the map->odom transformation (broadcasted by gmapping) changes: in theory to compensate odometry drift but, at the end, it spoils the estimate position of the robot. After position estimation is spoiled also laser scan data make no sense and this cause builded map to be... a no-sense! This make sense or I make some mistake in my think?
Just to give more info: the video show the robot just a minute after system starts. When the video starts the robot was stopped in its initial position: for this reason I expect base_link, odom and map frame overlap (drift must be zero and robot it's in center of map).
UPDATE
I'm still working in order to fix this problem. I performed some test to check the quality of my odometry. On the attached image from RViz you can see the laser data impressions drawn during complete test (decay time = 120000): consider that the robot travelled from one side of the room and back to its start position. Is it a good result? I think yes since when the robot go back to start position the laser scan is really close to original and the result is really close to real room. Unfortunately I have other material to compare to...
image description
Here the bag file recorded during this test. I used it to run gmapping and I got this map:
image description
I'm quite surprised to see that the raw laser scan data on odom frame represent the real world better than gmapping result! I expected gmapping to improve it...
Now I want to make some tests changing gmapping parameters. Has anyone some tips for me?
Thanks Ale
UPDATE
Looking for benchmark result of RPLidar I found this video uploaded by RoboPeak. I was really surprised by the quality of result and disappointed when compare it with my own ones! Since they was using hector_slam instead gmapping I tried the same and this is the result:
image description
This is really good compared to gmapping result. I want to go in deep on this topic and understand why they performed so different. Any tips?
Thanks
UPDATE
I'm working to some tests in order to find out how to improve gmapping performance in my robot. First test are conducted setting different values of minimum score param in gmapping.
Here the result:
image description
The improvement with value of 500 is a fake: with this value gmapping rely in odometry only! So minimum score is not the solution.
For next test I want to use a scan filter in order to clean laser scan data and check if this can improve gmapping result.
For who is interested a benchmark of different SLAM algorithm available in ROS can be found here.
SOLVED
At the end I found how to fix gmapping and RPLidar problem. The problem came out from different sources:
  • the LaserScan message expected by GMapping;
  • the RPLidar reference frame;
  • the LaserScan message created by RPLidar node.
Here there is the RPLidar node with fixes and here you can find more information about the fix.
In order to make RPLidar and gmapping work some attention is required broadcasting laser frame transformation. Please read the posted link for complete explanation.
Originally posted by afranceson on ROS Answers with karma: 497 on 2015-03-22
Post score: 4
Hi, afranceson
I am building a SLAM system which is very similiar to yours (with RPLidar + gmapping).
I'm not familiar with the odometry used in such systems. So can you offer me some information about the odometry you used? Or would you please recommend me a good odometry which is well suited for ROS and my system. FYI, my vehicle is a four-wheel rear-drive car which is made by myself. I'd llike to offer any detail about my vehicle if it is needed.
Thank you in advance!
Originally posted by Clack with karma: 75 on 2016-03-14
Comment by afranceson on 2016-03-14:
Dear Clack,
on my robot I'm using MD25 motor control board and EMG30 motors. They provide encoders with 360 clicks per revolution and feedback. This works quite well on my robot.
On www.geduino.org you can find more info and sources. Feel free to contact me, I will be happy to help you.
Regards
Comment by Clack on 2016-03-14:
Thank you so much! I think I'd better collect some information on those devices first :)
Comment by Icehawk101 on 2016-03-22:
Another option would be to use the laser_scan_matcher package to simulate odometry info.
Comment by Clack on 2016-03-22:
Thanks to your advice, Icehawk. But we've decided to use a real odometry in our system :)
Comment by afranceson on 2016-03-23:
Anyway, if you want to use the laser scan data only you should consider to use Hector Slam instead of Gmapping.
Comment by Clack on 2016-03-23:
Thanks, I'll see to that :)
The transformation between odom and base_link represents your robot's best estimate of odometry using wheel odometry (thought you may potentially fuse other sources using robot_pose_ekf or robot_localization), so the two frames should not overlap.
In the perfect-odometry case, odom and map would overlap. The transform represents gmapping's localization correction. It looks like your odometry drifts quite a bit based on the video. Have you tried tuning it based on the nav stack guide (http://wiki.ros.org/navigation/Tutorials/Navigation%20Tuning%20Guide#Odometry)?
If you get a lot of natural drift in odometry, you could try increasing srr, srt, str, stt parameters to pass that information to gmapping.
Finally, increasing the particle count is always a good bet, although it makes gmapping more processor intensive.
EDIT That laserscan overlay DOES look fairly consistent. Maybe your issue is more with sensor noise then? I've never benchmarked an RPLidar, but I know they're on the cheap side. I'm not sure if there's anything you can tweak in gmapping to help account for that - maybe using a larger grid size, or the increasing minimumScore parameter?
Originally posted by paulbovbel with karma: 4518 on 2015-03-22
Comment by afranceson on 2015-03-23:
Thanks for your suggestion: I follow the guide and sensor data and odometry result quite good for forward/back direction, for rotation can be improved. Any way on my test I only move my robot forward and the drift in rotation does not explain the big error I see on RViz.
Comment by RND on 2015-04-18:
paulbovbel, is it possible to get localization information from the GMapping node itself? I need a good pose estimate that comes from the SLAM algorithm itself not from the odometry data. I need to use it in an exploration algorithm.
Also, can you briefly explain to me what are the meanings of srr, srt, str and stt with respect to the gmapping SLAM algorithm? What are we doing if we increase these parameters? thanks
Comment by paulbovbel on 2015-04-21:
@RND, read the gmapping ROS wiki first.
