I'm a beginner in Robotics.
I'd like to ask what are the minimum/recommended specs for a microcontroller to run a real-time system such as Linux RTAI?
What is the popular microcontroller for running Linux RTAI?
Thank you.
  • 2
    $\begingroup$ You need to check first which architectures RTAI supports. The latest versions support only x86 and x86_64, with support for ARM lagging behind a couple versions. Some other architectures had been supported at some point in the past, but there hasn't been any activity on them for a very long time. That's the minimum specs for the microcontroller: having RTAI actually support it. $\endgroup$
    – Shahbaz
    Commented Feb 22, 2015 at 12:33
