I create ros package named pioneer3at_gazebo in catkin_ws/src;
then I do catkin_make install; when i use roscd pioneer3at_gazebo, the path show in catkin_make/install.
why that happen?
Originally posted by crazymumu on ROS Answers with karma: 214 on 2015-03-19
What did you expect would happen?
catkin_make install does just what it says: it makes (builds) things first,then installs them into the default location (which is /path/to/catkin_ws/install).
If you then do source /path/to/catkin_ws/install/setup.bash, your ROS_PACKAGE_PATH is set to include locations under /path/to/catkin_ws/install, so a roscd PKG will take you there, instead of devel/.
For some more info, see catkin/workspaces on the ROS wiki. I think especially the Catkin Workspaces section should be helpful.
Originally posted by gvdhoorn with karma: 86574 on 2015-03-20
