Looking at the CMakeLists.txt for pr2_2dnav
for Hydro, it would appear that the launch file is not installed (the build script is missing an install(..)
rule). That would result in the error message you quoted.
You can check this by doing a ls -al /opt/ros/hydro/share/pr2_2dnav/
and then look for the pr2_2dnav.launch
file in the listing. It will most likely not be there.
If the file is missing, please log an issue on the pr2_navigation_apps
issue tracker.
Originally posted by gvdhoorn with karma: 86574 on 2015-03-17
Comment by pexison on 2015-03-17:
under this directory is only a cmake
folder and a package.xml
file, there are no more files/folders. Should I log an issue then?
Comment by gvdhoorn on 2015-03-17:
Yes, file an issue and please add a link to this question to the issue.
Comment by DevonW on 2015-03-17:
Thanks for bringing this up. I've fixed it and re-released it. See: https://github.com/ros/rosdistro/pull/7546
Comment by pexison on 2015-03-18:
By the way, it is possible to use this library for the turtlebot? or it is only for PR2 robot?
Comment by DevonW on 2015-03-18:
Please open a new question if this one is answered.
