Currently this is the code that I have, and I am able to get the robot moving by editing the linear x or angular z values (speed).
#include <ros/ros.h>
#include <geometry_msgs/Twist.h>
ros::init(argc, argv, "move_pub");
ros::NodeHandle n;
ros::Publisher movement_pub = n.advertise<geometry_msgs::Twist>("mobile_base/commands/velocity",1);
ros::Rate rate(10);
while (ros::ok())
    geometry_msgs::Twist move;
    //velocity controls
    move.linear.x = -0.1; //speed value m/s
    move.angular.z = 0;
    movement_pub.publish(move);
    ros::spinOnce();
    rate.sleep();
return 0;
Is there a time control in ROS? Whereby I can do something like while time <= 5s, publish linear x velocity of 0.2m/s. Thus, covering 1 meter. I am new to ROS and it is my first week into it. Im working on the TurtleBot 2.
Originally posted by dylankc on ROS Answers with karma: 13 on 2015-03-16
Comment by gvdhoorn on 2015-03-16:
Also see robot pose slightly off when publishing to /cmd_vel for some discussion on the feasibility of what you are trying to achieve.
There is ros::Time and ros::Duration, which can be used in an intuitive way. ros::Time::now() gives you the current time. You probably want something like:
ros::Time start = ros::Time::now()
while(ros::Time::now() - start < ros::Duration(5.0))
Originally posted by dornhege with karma: 31395 on 2015-03-16
Comment by dylankc on 2015-03-16:
Thank you dornhege for teaching me about the ros::Time & ros::Duration function. However, i've taken a look at "http://answers.ros.org/question/204973/robot-pose-slightly-off-when-publishing-to-cmd_vel/" and realized that my method is prone to inaccuracy!
I'll try publishing to /odom.
I appreciate your help very much. Thank you
