I'm am trying to utilize the Microsoft Kinect for navigation. I am utilizing ROS Hydro on Ubuntu 12.04.
I have not figured out how to use the navigation stack yet, so if you have any pointers on that, send them my way.
I have noticed that most of the navigation packages require /laserscan rather than/pointcloud2, so I have begun to try to get pointcloud_to_laserscan up and running.
I downloaded the package utilizing:
git clone https://github.com/ros-perception/perception_pcl.git
but when I ran catkin_make I received the following error:
CMake Error at /opt/ros/hydro/share/catkin/cmake/catkinConfig.cmake:75 (find_package):
  Could not find a configuration file for package tf2_sensor_msgs.
  Set tf2_sensor_msgs_DIR to the directory containing a CMake configuration
  file for tf2_sensor_msgs.  The file will have one of the following names:
    tf2_sensor_msgsConfig.cmake
    tf2_sensor_msgs-config.cmake
  perception_pcl/pointcloud_to_laserscan/CMakeLists.txt:4 (find_package)
CMake Error at perception_pcl/pcl_ros/CMakeLists.txt:5 (find_package):
  Could not find module Findcmake_modules.cmake or a configuration file for
  package cmake_modules.
  Adjust CMAKE_MODULE_PATH to find Findcmake_modules.cmake or set
  cmake_modules_DIR to the directory containing a CMake configuration file
  for cmake_modules.  The file will have one of the following names:
    cmake_modulesConfig.cmake
    cmake_modules-config.cmake
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
I'm relatively new at this. Any thoughts?
Originally posted by sealguy77 on ROS Answers with karma: 323 on 2015-03-09
Comment by Mekateng on 2018-06-17:
Hi, Did you convert pointcloud to laserscan?
This is because you cloned the repo, but did not install any dependencies. To install dependencies you would run:
rosdep install --from-paths src --ignore-src --rosdistro hydro -y
Incidentally you cloned the indigo-devel branch by default, which will not work on hydro.
Why not just install the binaries via apt-get? This will pull in all dependencies automatically:
sudo apt-get install ros-hydro-pointcloud-to-laserscan
Originally posted by paulbovbel with karma: 4518 on 2015-03-09
Comment by sealguy77 on 2015-03-09:
Good question...
sudo apt-get worked just fine.
Thanks.
