Hello,
I'm spawning 2 pioneer robots but I have some plug-ins for the sensors, odom and cmd/vel that are publishing for the same topics.
Is there any simple/and efficient way to change the topics where they are publishing this messages? The robots have different names already. Anyone knows how to do this?
I don't want just to copy paste all the xacro code and change the topics by hand, I think its not a good solution.
Anyone knows how to do this? So far I created 2 launch files to try to do this:
 <launch>
    <param name="/use_sim_time" value="true"/>
    <include file="$(find gazebo_ros)/launch/empty_world.launch"/>
  <group ns="p3dx_1">
    <include file="$(find p3dx_gazebo)/launch/pioneer.launch">
      <arg name="name" value="p3dx_1"/>
      <arg name="pos_x" value="-4.0"/>
      <arg name="namespace_arg" value="p3dx_1"/>
    </include>
  </group>
  <group ns="p3dx_2">
      <arg name="name" value="p3dx_2"/>
      <arg name="pos_x" value="4.0"/>
      <arg name="namespace_arg" value="p3dx_2"/>
    </include>
  </group>
</launch>
and this one:
<launch>
  <!-- push robot_description to factory and spawn robot in gazebo -->
  <arg name="name" default="pioneer"/>
  <arg name="pos_x" default="0.0"/>
  <arg name="pos_y" default="0.0"/>
  <arg name="pos_z" default="0.0"/>
  <arg name="namespace_arg" default=""/>
  <arg name="model" default="$(find p3dx_description)/urdf/$(arg namespace_arg).xacro"/>
  <!-- send the robot XML to param server -->
  <param name="robot_description" command="$(find xacro)/xacro.py '$(arg model)'" />
  <param name="tf_prefix" value="$(arg namespace_arg)" />
  <node name="spawn_robot" pkg="gazebo_ros" type="spawn_model"
        args="-param robot_description
              -urdf
              -x $(arg pos_x)
              -y $(arg pos_y)
              -z $(arg pos_z)
              -model $(arg name)"
        respawn="false" output="screen">
  </node>
</launch>
But I think this way I will have to copy the .xacro files. Anyone has a better idea?
Originally posted by End-Effector on ROS Answers with karma: 162 on 2015-03-05
I just tried it myself with my robot. One thing you need are groups in launchfiles.
http://wiki.ros.org/roslaunch/XML/group
BTW. If you use robot namespace tags in your model plugins, remove them!
Otherwise your topics like for example cmd_vel will overlap.
You also need another parameter with a different name for the other robot because I found out they are named like the param in gazebo.
Put the same launch tags (except the parameter for the spawn and spawn position) for your robots in two tags,
For example:
<node name="spawn_test_bot" pkg="gazebo_ros" type="spawn_model" args="-z 0.1 -urdf -param robot_description -model robot_description" respawn="false" />
 <node name="spawn_test_bot" pkg="gazebo_ros" type="spawn_model" args="-z 0.1 -x 1 -urdf -param robot_description2 -model robot_description2" respawn="false" />
That seems to work for me, but currently I just need one robot.
Originally posted by LucianTM with karma: 62 on 2015-03-06
Comment by cybodroid on 2015-12-13:
how did you make it work? node nam must be unique!
