I have been asked to write code to implement serial communications with a camera in order to control its pedestal (movable base) as well as set a few dozen other camera options. The catch is that I have to make it usable by ROS.
What would be the best practice to implement this functionality in ROS? I understand the concept of services, but I think that there should be a better way than creating a different service/file for each option.
Thanks, Daniel.
  • $\begingroup$ This question is probably better suited to answers.ros.org because it is only about ROS and not specifically robotics. $\endgroup$
    – Ben
    Feb 17, 2015 at 0:46
Why not write a subscription based node? It could take messages from whoever then passes the information on to the camera. From what you've said, it seems like a service wouldn't be necessary.
Response. Yes. Create a new message that has all the necessary fields and a new topic, maybe /camera_parameters.
  • $\begingroup$ This does seem like a better idea. Would you suggest creating a topic with all the parameters? $\endgroup$ Feb 16, 2015 at 21:21
