-4
I was wondering what options are there in terms of lightweight (< 5 lbs) robotic arms. I see Robai Cyton Gamma 300, and CrustCrawler AX18 look like interesting options. What lightweight arms do people use/like?
5
  • 3
    $\begingroup$ In general, survey questions are not a good fit, and will get closed or downvoted. This site is for specific problems you are having. If you want to pursue this question, could you please add more details? For instance, what is your intended application, what does "interesting" mean, what are the cost constraints / programability constraints? Think of someone who may visit this page in the future. How would they know if they can use this information for their application? $\endgroup$ Dec 11, 2012 at 23:38
    $\begingroup$ @Josh though i'm not answering, appreciate your comment. Because many of the others just down-vote/close-vote without saying any reason (I feel like it's so rude). And JES what josh said is right. Refer this to know more. $\endgroup$
    – Anubis
    Dec 12, 2012 at 3:12
    $\begingroup$ Welcome to Robotics JES, but we try to avoid shopping questions as they are not very useful to future visitors to the site and go out of date quickly. We prefer practical, answerable questions based on actual problems that you face so if you can rephrase your question to ask what things you need to consider when selecting a robot arm, you may get answers which are both useful now and in the future. Thanks, $\endgroup$
    – Mark Booth
    Dec 12, 2012 at 10:36
  • $\begingroup$ Welcome to robotics.SE. A few more details would be helpful. How much weight should it be able to lift, do you need a certain number of degrees of freedom, do you need it to connect directly to a PC or are you comfortable with it connecting to something like an Arduino? $\endgroup$
    – ThomasH
    Dec 13, 2012 at 8:07
  • $\begingroup$ Sorry about that (I'm new to robotics.SE). I want to lift approximately 500 grams. Initially, looking for 4 DoF+. I would be comfortable programming Arduino. $\endgroup$
    – JES
    Dec 14, 2012 at 12:37
Have you thought about cardboard? http://www.kickstarter.com/projects/392540503/cardboard-robot-robotic-arm-and-smart-phone-camera
The OWI robotic arm is a cheap starting possibility for $30. There is an instructables tutorial on how to connect it to arduino.
