I am learning ROS at the moment using the tutorial available here on this page. http://wiki.ros.org/ROS/Tutorials/CreatingMsgAndSrv I am so far, but for some reason not come past opening the CMakeList.txt using rosed roscpp
it says that it cannot find the package eventhough i am inside the folder. I've changes the package.xml... I changed using nano, and tried to make a rosmsg show of the num.msg i've created at the begining, but the output is not as should be.. What is wrong here....
I not even able to my way to the folder beginner_tutorials ..... using rosmsg show
The output I get when i rosmsg show beginner_tutorials/Num is
Unable to load msg [beginner_tutorials/Num]: Cannot locate message [Num]: unknown package [beginner_tutorials] on search path [{'rosconsole': ['/opt/ros/indigo/share/rosconsole/msg'], 'catkin': ['/opt/ros/indigo/share/catkin/msg'], 'angles': ['/opt/ros/indigo/share/angles/msg'], 'image_view': ['/opt/ros/indigo/share/image_view/msg'], 'carrot_planner': ['/opt/ros/indigo/share/carrot_planner/msg'], 'urdf': ['/opt/ros/indigo/share/urdf/msg'], 'rosgraph': ['/opt/ros/indigo/share/rosgraph/msg'], 'rqt_py_console': ['/opt/ros/indigo/share/rqt_py_console/msg'], 'nodelet_topic_tools': ['/opt/ros/indigo/share/nodelet_topic_tools/msg'], 'rqt_graph': ['/opt/ros/indigo/share/rqt_graph/msg'], 'rotate_recovery': ['/opt/ros/indigo/share/rotate_recovery/msg'], 'theora_image_transport': ['/opt/ros/indigo/share/theora_image_transport/msg'], 'rocon_python_comms': ['/opt/ros/indigo/share/rocon_python_comms/msg'], 'qt_gui': ['/opt/ros/indigo/share/qt_gui/msg'], 'filters': ['/opt/ros/indigo/share/filters/msg'], 'ecl_exceptions': ['/opt/ros/indigo/share/ecl_exceptions/msg'], 'navfn': ['/opt/ros/indigo/share/navfn/msg'], 'dwa_local_planner': ['/opt/ros/indigo/share/dwa_local_planner/msg'], 'rosgraph_msgs': ['/opt/ros/indigo/share/rosgraph_msgs/msg'], 'smclib': ['/opt/ros/indigo/share/smclib/msg'], 'ecl_devices': ['/opt/ros/indigo/share/ecl_devices/msg'], 'rocon_gateway_utils': ['/opt/ros/indigo/share/rocon_gateway_utils/msg'], 'roscpp_serialization': ['/opt/ros/indigo/share/roscpp_serialization/msg'], 'rqt_rviz': ['/opt/ros/indigo/share/rqt_rviz/msg'], 'rosbuild': ['/opt/ros/indigo/share/rosbuild/msg'], 'qt_gui_cpp': ['/opt/ros/indigo/share/qt_gui_cpp/msg'], 'rosauth': ['/opt/ros/indigo/share/rosauth/msg'], 'tf': ['/opt/ros/indigo/share/tf/msg'], 'rqt_publisher': ['/opt/ros/indigo/share/rqt_publisher/msg'], 'roslang': ['/opt/ros/indigo/share/roslang/msg'], 'geometric_shapes': ['/opt/ros/indigo/share/geometric_shapes/msg'], 'kobuki_driver': ['/opt/ros/indigo/share/kobuki_driver/msg'], 'smach_ros': ['/opt/ros/indigo/share/smach_ros/msg'], 'genlisp': ['/opt/ros/indigo/share/genlisp/msg'], 'map_server': ['/opt/ros/indigo/share/map_server/msg'], 'interactive_markers': ['/opt/ros/indigo/share/interactive_markers/msg'], 'dynamic_reconfigure': ['/opt/ros/indigo/share/dynamic_reconfigure/msg'], 'ecl_containers': ['/opt/ros/indigo/share/ecl_containers/msg'], 'diagnostic_aggregator': ['/opt/ros/indigo/share/diagnostic_aggregator/msg'], 'ecl_license': ['/opt/ros/indigo/share/ecl_license/msg'], 'smart_battery_msgs': ['/opt/ros/indigo/share/smart_battery_msgs/msg'], 'robot_state_publisher': ['/opt/ros/indigo/share/robot_state_publisher/msg'], 'visualization_msgs': ['/opt/ros/indigo/share/visualization_msgs/msg'], 'diagnostic_updater': ['/opt/ros/indigo/share/diagnostic_updater/msg'], 'ecl_streams': ['/opt/ros/indigo/share/ecl_streams/msg'], 'resource_retriever': ['/opt/ros/indigo/share/resource_retriever/msg'], 'rqt_topic': ['/opt/ros/indigo/share/rqt_topic/msg'], 'smach': ['/opt/ros/indigo/share/smach/msg'], 'ecl_mpl': ['/opt/ros/indigo/share/ecl_mpl/msg'], 'stdr_parser': ['/opt/ros/indigo/share/stdr_parser/msg'], 'ecl_math': ['/opt/ros/indigo/share/ecl_math/msg'], 'rqt_action': ['/opt/ros/indigo/share/rqt_action/msg'], 'rqt_top': ['/opt/ros/indigo/share/rqt_top/msg'], 'rosbridge_server': ['/opt/ros/indigo/share/rosbridge_server/msg'], 'diagnostic_msgs': ['/opt/ros/indigo/share/diagnostic_msgs/msg'], 'move_base': ['/opt/ros/indigo/share/move_base/msg'], 'rosboost_cfg': ['/opt/ros/indigo/share/rosboost_cfg/msg'], 'genmsg': ['/opt/ros/indigo/share/genmsg/msg'], 'xacro': ['/opt/ros/indigo/share/xacro/msg'], 'turtle_tf2': ['/opt/ros/indigo/share/turtle_tf2/msg'], 'rqt_robot_dashboard': ['/opt/ros/indigo/share/rqt_robot_dashboard/msg'], 'pluginlib': ['/opt/ros/indigo/share/pluginlib/msg'], 'xmlrpcpp': ['/opt/ros/indigo/share/xmlrpcpp/msg'], 'rqt_service_caller': ['/opt/ros/indigo/share/rqt_service_caller/msg'], 'ar_track_alvar': ['/opt/ros/indigo/share/ar_track_alvar/msg'], 'rqt_msg': ['/opt/ros/indigo/share/rqt_msg/msg'], 'geometry_msgs': ['/opt/ros/indigo/share/geometry_msgs/msg'], 'rosmaster': ['/opt/ros/indigo/share/rosmaster/msg'], 'warehouse_ros': ['/opt/ros/indigo/share/warehouse_ros/msg'], 'yocs_velocity_smoother': ['/opt/ros/indigo/share/yocs_velocity_smoother/msg'], 'rosnode': ['/opt/ros/indigo/share/rosnode/msg'], 'rqt_pose_view': ['/opt/ros/indigo/share/rqt_pose_view/msg'], 'rocon_app_manager': ['/opt/ros/indigo/share/rocon_app_manager/msg'], 'bond': ['/opt/ros/indigo/share/bond/msg'], 'rocon_apps': ['/opt/ros/indigo/share/rocon_apps/msg'], 'image_geometry': ['/opt/ros/indigo/share/image_geometry/msg'], 'rocon_app_utilities': ['/opt/ros/indigo/share/rocon_app_utilities/msg'], 'rospack': ['/opt/ros/indigo/share/rospack/msg'], 'rocon_semantic_version': ['/opt/ros/indigo/share/rocon_semantic_version/msg'], 'actionlib_msgs': ['/opt/ros/indigo/share/actionlib_msgs/msg'], 'image_rotate': ['/opt/ros/indigo/share/image_rotate/msg'], 'rqt_image_view': ['/opt/ros/indigo/share/rqt_image_view/msg'], 'rgbd_launch': ['/opt/ros/indigo/share/rgbd_launch/msg'], 'yocs_msgs': ['/opt/ros/indigo/share/yocs_msgs/msg'], 'roslisp': ['/opt/ros/indigo/share/roslisp/msg'], 'rqt_console': ['/opt/ros/indigo/share/rqt_console/msg'], 'joint_state_publisher': ['/opt/ros/indigo/share/joint_state_publisher/msg'], 'rocon_std_msgs': ['/opt/ros/indigo/share/rocon_std_msgs/msg'], 'ecl_sigslots': ['/opt/ros/indigo/share/ecl_sigslots/msg'], 'rviz_plugin_tutorials': ['/opt/ros/indigo/share/rviz_plugin_tutorials/msg'], 'tf2_msgs': ['/opt/ros/indigo/share/tf2_msgs/msg'], 'python_qt_binding': ['/opt/ros/indigo/share/python_qt_binding/msg'], 'laser_geometry': ['/opt/ros/indigo/share/laser_geometry/msg'], 'clear_costmap_recovery': ['/opt/ros/indigo/share/clear_costmap_recovery/msg'], 'rviz': ['/opt/ros/indigo/share/rviz/msg'], 'rocon_master_info': ['/opt/ros/indigo/share/rocon_master_info/msg'], 'gencpp': ['/opt/ros/indigo/share/gencpp/msg'], 'rqt_gui_cpp': ['/opt/ros/indigo/share/rqt_gui_cpp/msg'], 'rqt_bag': ['/opt/ros/indigo/share/rqt_bag/msg'], 'rqt_gui': ['/opt/ros/indigo/share/rqt_gui/msg'], 'qt_gui_py_common': ['/opt/ros/indigo/share/qt_gui_py_common/msg'], 'eigen_conversions': ['/opt/ros/indigo/share/eigen_conversions/msg'], 'roscpp_traits': ['/opt/ros/indigo/share/roscpp_traits/msg'], 'driver_base': ['/opt/ros/indigo/share/driver_base/msg'], 'rosout': ['/opt/ros/indigo/share/rosout/msg'], 'diagnostic_common_diagnostics': ['/opt/ros/indigo/share/diagnostic_common_diagnostics/msg'], 'rostopic': ['/opt/ros/indigo/share/rostopic/msg'], 'rospy_tutorials': ['/opt/ros/indigo/share/rospy_tutorials/msg'], 'smach_msgs': ['/opt/ros/indigo/share/smach_msgs/msg'], 'message_generation': ['/opt/ros/indigo/share/message_generation/msg'], 'camera_calibration': ['/opt/ros/indigo/share/camera_calibration/msg'], 'kobuki_gazebo': ['/opt/ros/indigo/share/kobuki_gazebo/msg'], 'rocon_gateway': ['/opt/ros/indigo/share/rocon_gateway/msg'], 'polled_camera': ['/opt/ros/indigo/share/polled_camera/msg'], 'gazebo_plugins': ['/opt/ros/indigo/share/gazebo_plugins/msg'], 'gazebo_msgs': ['/opt/ros/indigo/share/gazebo_msgs/msg'], 'ecl_threads': ['/opt/ros/indigo/share/ecl_threads/msg'], 'rostime': ['/opt/ros/indigo/share/rostime/msg'], 'rqt_nav_view': ['/opt/ros/indigo/share/rqt_nav_view/msg'], 'turtlebot_navigation': ['/opt/ros/indigo/share/turtlebot_navigation/msg'], 'urdf_tutorial': ['/opt/ros/indigo/share/urdf_tutorial/msg'], 'kobuki_auto_docking': ['/opt/ros/indigo/share/kobuki_auto_docking/msg'], 'ecl_time_lite': ['/opt/ros/indigo/share/ecl_time_lite/msg'], 'rosservice': ['/opt/ros/indigo/share/rosservice/msg'], 'rospy': ['/opt/ros/indigo/share/rospy/msg'], 'kdl_conversions': ['/opt/ros/indigo/share/kdl_conversions/msg'], 'turtle_tf': ['/opt/ros/indigo/share/turtle_tf/msg'], 'roscpp_tutorials': ['/opt/ros/indigo/share/roscpp_tutorials/msg'], 'ecl_build': ['/opt/ros/indigo/share/ecl_build/msg'], 'roscpp': ['/opt/ros/indigo/share/roscpp/msg'], 'openni_launch': ['/opt/ros/indigo/share/openni_launch/msg'], 'turtle_actionlib': ['/opt/ros/indigo/share/turtle_actionlib/msg'], 'python_orocos_kdl': ['/opt/ros/indigo/share/python_orocos_kdl/msg'], 'stage': ['/opt/ros/indigo/share/stage/msg'], 'roslint': ['/opt/ros/indigo/share/roslint/msg'], 'depthimage_to_laserscan': ['/opt/ros/indigo/share/depthimage_to_laserscan/msg'], 'visualization_marker_tutorials': ['/opt/ros/indigo/share/visualization_marker_tutorials/msg'], 'bondcpp': ['/opt/ros/indigo/share/bondcpp/msg'], 'rosconsole_bridge': ['/opt/ros/indigo/share/rosconsole_bridge/msg'], 'pluginlib_tutorials': ['/opt/ros/indigo/share/pluginlib_tutorials/msg'], 'gateway_msgs': ['/opt/ros/indigo/share/gateway_msgs/msg'], 'camera_calibration_parsers': ['/opt/ros/indigo/share/camera_calibration_parsers/msg'], 'rocon_service_pair_msgs': ['/opt/ros/indigo/share/rocon_service_pair_msgs/msg'], 'roslz4': ['/opt/ros/indigo/share/roslz4/msg'], 'rqt_dep': ['/opt/ros/indigo/share/rqt_dep/msg'], 'ecl_converters': ['/opt/ros/indigo/share/ecl_converters/msg'], 'rocon_python_utils': ['/opt/ros/indigo/share/rocon_python_utils/msg'], 'rosmsg': ['/opt/ros/indigo/share/rosmsg/msg'], 'turtlebot_description': ['/opt/ros/indigo/share/turtlebot_description/msg'], 'actionlib_tutorials': ['/opt/ros/indigo/share/actionlib_tutorials/msg'], 'turtlesim': ['/opt/ros/indigo/share/turtlesim/msg'], 'amcl': ['/opt/ros/indigo/share/amcl/msg'], 'rocon_uri': ['/opt/ros/indigo/share/rocon_uri/msg'], 'rqt_robot_monitor': ['/opt/ros/indigo/share/rqt_robot_monitor/msg'], 'rocon_ebnf': ['/opt/ros/indigo/share/rocon_ebnf/msg'], 'self_test': ['/opt/ros/indigo/share/self_test/msg'], 'roslib': ['/opt/ros/indigo/share/roslib/msg'], 'diagnostic_analysis': ['/opt/ros/indigo/share/diagnostic_analysis/msg'], 'stereo_msgs': ['/opt/ros/indigo/share/stereo_msgs/msg'], 'kobuki_gazebo_plugins': ['/opt/ros/indigo/share/kobuki_gazebo_plugins/msg'], 'kobuki_capabilities': ['/opt/ros/indigo/share/kobuki_capabilities/msg'], 'pcl_msgs': ['/opt/ros/indigo/share/pcl_msgs/msg'], 'trajectory_msgs': ['/opt/ros/indigo/share/trajectory_msgs/msg'], 'create_driver': ['/opt/ros/indigo/share/create_driver/msg'], 'move_base_msgs': ['/opt/ros/indigo/share/move_base_msgs/msg'], 'capabilities': ['/opt/ros/indigo/share/capabilities/msg'], 'turtlebot_gazebo': ['/opt/ros/indigo/share/turtlebot_gazebo/msg'], 'laser_assembler': ['/opt/ros/indigo/share/laser_assembler/msg'], 'ecl_errors': ['/opt/ros/indigo/share/ecl_errors/msg'], 'pcl_conversions': ['/opt/ros/indigo/share/pcl_conversions/msg'], 'fake_localization': ['/opt/ros/indigo/share/fake_localization/msg'], 'rviz_python_tutorial': ['/opt/ros/indigo/share/rviz_python_tutorial/msg'], 'robot_pose_publisher': ['/opt/ros/indigo/share/robot_pose_publisher/msg'], 'tf2': ['/opt/ros/indigo/share/tf2/msg'], 'rqt_runtime_monitor': ['/opt/ros/indigo/share/rqt_runtime_monitor/msg'], 'ecl_eigen': ['/opt/ros/indigo/share/ecl_eigen/msg'], 'rosbash': ['/opt/ros/indigo/share/rosbash/msg'], 'rqt_reconfigure': ['/opt/ros/indigo/share/rqt_reconfigure/msg'], 'rqt_bag_plugins': ['/opt/ros/indigo/share/rqt_bag_plugins/msg'], 'bfl': ['/opt/ros/indigo/share/bfl/msg'], 'rqt_launch': ['/opt/ros/indigo/share/rqt_launch/msg'], 'rocon_python_redis': ['/opt/ros/indigo/share/rocon_python_redis/msg'], 'yocs_controllers': ['/opt/ros/indigo/share/yocs_controllers/msg'], 'rqt_plot': ['/opt/ros/indigo/share/rqt_plot/msg'], 'topic_tools': ['/opt/ros/indigo/share/topic_tools/msg'], 'rostest': ['/opt/ros/indigo/share/rostest/msg'], 'ecl_time': ['/opt/ros/indigo/share/ecl_time/msg'], 'tf_conversions': ['/opt/ros/indigo/share/tf_conversions/msg'], 'control_msgs': ['/opt/ros/indigo/share/control_msgs/msg'], 'cpp_common': ['/opt/ros/indigo/share/cpp_common/msg'], 'nodelet': ['/opt/ros/indigo/share/nodelet/msg'], 'nodelet_tutorial_math': ['/opt/ros/indigo/share/nodelet_tutorial_math/msg'], 'rqt_robot_steering': ['/opt/ros/indigo/share/rqt_robot_steering/msg'], 'kobuki_msgs': ['/opt/ros/indigo/share/kobuki_msgs/msg'], 'genpy': ['/opt/ros/indigo/share/genpy/msg'], 'tf2_geometry_msgs': ['/opt/ros/indigo/share/tf2_geometry_msgs/msg'], 'ar_track_alvar_msgs': ['/opt/ros/indigo/share/ar_track_alvar_msgs/msg'], 'compressed_image_transport': ['/opt/ros/indigo/share/compressed_image_transport/msg'], 'rqt_shell': ['/opt/ros/indigo/share/rqt_shell/msg'], 'zeroconf_msgs': ['/opt/ros/indigo/share/zeroconf_msgs/msg'], 'roscreate': ['/opt/ros/indigo/share/roscreate/msg'], 'image_transport': ['/opt/ros/indigo/share/image_transport/msg'], 'stdr_resources': ['/opt/ros/indigo/share/stdr_resources/msg'], 'ecl_mobile_robot': ['/opt/ros/indigo/share/ecl_mobile_robot/msg'], 'rocon_app_manager_msgs': ['/opt/ros/indigo/share/rocon_app_manager_msgs/msg'], 'rocon_python_wifi': ['/opt/ros/indigo/share/rocon_python_wifi/msg'], 'qt_dotgraph': ['/opt/ros/indigo/share/qt_dotgraph/msg'], 'stdr_gui': ['/opt/ros/indigo/share/stdr_gui/msg'], 'ecl_geometry': ['/opt/ros/indigo/share/ecl_geometry/msg'], 'cv_bridge': ['/opt/ros/indigo/share/cv_bridge/msg'], 'gazebo_ros': ['/opt/ros/indigo/share/gazebo_ros/msg'], 'rosbag_storage': ['/opt/ros/indigo/share/rosbag_storage/msg'], 'ecl_utilities': ['/opt/ros/indigo/share/ecl_utilities/msg'], 'rocon_hub': ['/opt/ros/indigo/share/rocon_hub/msg'], 'roswtf': ['/opt/ros/indigo/share/roswtf/msg'], 'std_srvs': ['/opt/ros/indigo/share/std_srvs/msg'], 'eigen_stl_containers': ['/opt/ros/indigo/share/eigen_stl_containers/msg'], 'rospy_message_converter': ['/opt/ros/indigo/share/rospy_message_converter/msg'], 'ecl_concepts': ['/opt/ros/indigo/share/ecl_concepts/msg'], 'global_planner': ['/opt/ros/indigo/share/global_planner/msg'], 'mk': ['/opt/ros/indigo/share/mk/msg'], 'octomap': ['/opt/ros/indigo/share/octomap/msg'], 'rocon_hub_client': ['/opt/ros/indigo/share/rocon_hub_client/msg'], 'stage_ros': ['/opt/ros/indigo/share/stage_ros/msg'], 'ecl_linear_algebra': ['/opt/ros/indigo/share/ecl_linear_algebra/msg'], 'stereo_image_proc': ['/opt/ros/indigo/share/stereo_image_proc/msg'], 'joy': ['/opt/ros/indigo/share/joy/msg'], 'bondpy': ['/opt/ros/indigo/share/bondpy/msg'], 'collada_urdf': ['/opt/ros/indigo/share/collada_urdf/msg'], 'stdr_robot': ['/opt/ros/indigo/share/stdr_robot/msg'], 'camera_info_manager': ['/opt/ros/indigo/share/camera_info_manager/msg'], 'kobuki_description': ['/opt/ros/indigo/share/kobuki_description/msg'], 'stdr_msgs': ['/opt/ros/indigo/share/stdr_msgs/msg'], 'rqt_web': ['/opt/ros/indigo/share/rqt_web/msg'], 'ecl_formatters': ['/opt/ros/indigo/share/ecl_formatters/msg'], 'class_loader': ['/opt/ros/indigo/share/class_loader/msg'], 'tf2_py': ['/opt/ros/indigo/share/tf2_py/msg'], 'shape_msgs': ['/opt/ros/indigo/share/shape_msgs/msg'], 'kobuki_ftdi': ['/opt/ros/indigo/share/kobuki_ftdi/msg'], 'cmake_modules': ['/opt/ros/indigo/share/cmake_modules/msg'], 'nav_core': ['/opt/ros/indigo/share/nav_core/msg'], 'uuid_msgs': ['/opt/ros/indigo/share/uuid_msgs/msg'], 'create_node': ['/opt/ros/indigo/share/create_node/msg'], 'move_slow_and_clear': ['/opt/ros/indigo/share/move_slow_and_clear/msg'], 'rocon_console': ['/opt/ros/indigo/share/rocon_console/msg'], 'robot_pose_ekf': ['/opt/ros/indigo/share/robot_pose_ekf/msg'], 'create_description': ['/opt/ros/indigo/share/create_description/msg'], 'nav_msgs': ['/opt/ros/indigo/share/nav_msgs/msg'], 'rosmake': ['/opt/ros/indigo/share/rosmake/msg'], 'image_proc': ['/opt/ros/indigo/share/image_proc/msg'], 'costmap_2d': ['/opt/ros/indigo/share/costmap_2d/msg'], 'ecl_type_traits': ['/opt/ros/indigo/share/ecl_type_traits/msg'], 'kobuki_dock_drive': ['/opt/ros/indigo/share/kobuki_dock_drive/msg'], 'zeroconf_avahi': ['/opt/ros/indigo/share/zeroconf_avahi/msg'], 'depth_image_proc': ['/opt/ros/indigo/share/depth_image_proc/msg'], 'actionlib': ['/opt/ros/indigo/share/actionlib/msg'], 'laser_filters': ['/opt/ros/indigo/share/laser_filters/msg'], 'kobuki_safety_controller': ['/opt/ros/indigo/share/kobuki_safety_controller/msg'], 'kobuki_node': ['/opt/ros/indigo/share/kobuki_node/msg'], 'rosparam': ['/opt/ros/indigo/share/rosparam/msg'], 'rosunit': ['/opt/ros/indigo/share/rosunit/msg'], 'rosclean': ['/opt/ros/indigo/share/rosclean/msg'], 'std_capabilities': ['/opt/ros/indigo/share/std_capabilities/msg'], 'tf2_ros': ['/opt/ros/indigo/share/tf2_ros/msg'], 'turtlebot_bringup': ['/opt/ros/indigo/share/turtlebot_bringup/msg'], 'librviz_tutorial': ['/opt/ros/indigo/share/librviz_tutorial/msg'], 'rqt_moveit': ['/opt/ros/indigo/share/rqt_moveit/msg'], 'pcl_ros': ['/opt/ros/indigo/share/pcl_ros/msg'], 'base_local_planner': ['/opt/ros/indigo/share/base_local_planner/msg'], 'interactive_marker_tutorials': ['/opt/ros/indigo/share/interactive_marker_tutorials/msg'], 'shape_tools': ['/opt/ros/indigo/share/shape_tools/msg'], 'message_runtime': ['/opt/ros/indigo/share/message_runtime/msg'], 'stdr_server': ['/opt/ros/indigo/share/stdr_server/msg'], 'rqt_py_common': ['/opt/ros/indigo/share/rqt_py_common/msg'], 'message_filters': ['/opt/ros/indigo/share/message_filters/msg'], 'std_msgs': ['/opt/ros/indigo/share/std_msgs/msg'], 'kobuki_bumper2pc': ['/opt/ros/indigo/share/kobuki_bumper2pc/msg'], 'gmapping': ['/opt/ros/indigo/share/gmapping/msg'], 'yocs_cmd_vel_mux': ['/opt/ros/indigo/share/yocs_cmd_vel_mux/msg'], 'rosbridge_library': ['/opt/ros/indigo/share/rosbridge_library/msg'], 'random_numbers': ['/opt/ros/indigo/share/random_numbers/msg'], 'rosapi': ['/opt/ros/indigo/share/rosapi/msg'], 'rqt_srv': ['/opt/ros/indigo/share/rqt_srv/msg'], 'rqt_gui_py': ['/opt/ros/indigo/share/rqt_gui_py/msg'], 'voxel_grid': ['/opt/ros/indigo/share/voxel_grid/msg'], 'map_msgs': ['/opt/ros/indigo/share/map_msgs/msg'], 'rocon_icons': ['/opt/ros/indigo/share/rocon_icons/msg'], 'roslaunch': ['/opt/ros/indigo/share/roslaunch/msg'], 'compressed_depth_image_transport': ['/opt/ros/indigo/share/compressed_depth_image_transport/msg'], 'rqt_tf_tree': ['/opt/ros/indigo/share/rqt_tf_tree/msg'], 'openni_camera': ['/opt/ros/indigo/share/openni_camera/msg'], 'collada_parser': ['/opt/ros/indigo/share/collada_parser/msg'], 'rqt_logger_level': ['/opt/ros/indigo/share/rqt_logger_level/msg'], 'kobuki_random_walker': ['/opt/ros/indigo/share/kobuki_random_walker/msg'], 'ecl_command_line': ['/opt/ros/indigo/share/ecl_command_line/msg'], 'openslam_gmapping': ['/opt/ros/indigo/share/openslam_gmapping/msg'], 'kdl_parser': ['/opt/ros/indigo/share/kdl_parser/msg'], 'rosbag_migration_rule': ['/opt/ros/indigo/share/rosbag_migration_rule/msg'], 'media_export': ['/opt/ros/indigo/share/media_export/msg'], 'laptop_battery_monitor': ['/opt/ros/indigo/share/laptop_battery_monitor/msg'], 'kobuki_keyop': ['/opt/ros/indigo/share/kobuki_keyop/msg'], 'urdf_parser_plugin': ['/opt/ros/indigo/share/urdf_parser_plugin/msg'], 'ecl_config': ['/opt/ros/indigo/share/ecl_config/msg'], 'sensor_msgs': ['/opt/ros/indigo/share/sensor_msgs/msg'], 'orocos_kdl': ['/opt/ros/indigo/share/orocos_kdl/msg'], 'rosbag': ['/opt/ros/indigo/share/rosbag/msg'], 'kobuki_rapps': ['/opt/ros/indigo/share/kobuki_rapps/msg'], 'unique_id': ['/opt/ros/indigo/share/unique_id/msg']}]
Originally posted by 215 on ROS Answers with karma: 156 on 2015-02-02
Ok I'm not sur I got your problem:
Regarding rosed usage:
The main advantage of using rosed is that it uses the ROS package architecture. So you won't need to be inside any folder, you just need the environment variable $ROS_PACKAGE_PATH set. You set it by sourcing your workspace ("source ~/my_workspace/devel/setup.bash") and you shoud be able to use rosbash commands (roscd, rosls, rosed...).
rosed is working as follow : rosed PACKAGE_NAME FILENAME.
so if your run "rosed beginner_tutorial CMakeLists.txt" it will work
"rosed CMakeLists.txt" won't because CMakeLists.txt is a file, not a package.
If you are in the right folder you can just use "nano FILENAME", or "vim FILENAME" or any editor you use. rosed won't be of any value if you are already in the right package.
If your packages are not recognized:
source your workspace : "source ~/catkin_ws/devel/setup.bash"
update your package list : "rospack profile"
then you should be able to use rosbash commands : try "roscd beginner_tutorial"
If roscd works but rosmsg show doesn't work:
This means that your messages have not been generated. You need to build your package to generate the messages. To build your workspace you need to go in your workspace "cd ~/catkin_ws" and run "catking_make", you will see blue lines saying that your messages have been generated. Now rosmsg show should work
Hope this helps,
Originally posted by marguedas with karma: 3606 on 2015-02-02
Comment by 215 on 2015-02-03:
I tried them all, it doesn't work for my workspace.. would it help if i uploaded my workspace here? https://www.dropbox.com/s/dud6uwhmmxf93cf/link.txt?dl=0
Comment by marguedas on 2015-02-03:
catkin_ws doesn't appear in the console output you pasted. Are you sure your workspace has been sourced properly ? if you run "roscd" where do you end up ? in ~/catkin_ws/devel ? or /opt/ros/indigo ?
can you run the following ?
mkdir -p test_ws/src
cd test_ws/src
catkin_init_workspace
cp -r ~/catkin_ws/src/beginner_tutorials ./
cd ..
catkin_make
source ~/test_ws/devel/setup.bash
If you do it step by step there is no reason that this won't work
i don't why... but it works now..
ok cool, if you can vote to say that the question is solved this will allow to close it. Enjoy using ROS!
