Hi I am trying to use viso2 (https://github.com/srv/viso2) for visual odometry. I have the following setup:
The behavior that I am seeing is that most of the time the got_lost flag is set (in the /mono_odometer/info topic). And also the pose is not updated. But when I move the camera really fast, the flag changes for one frame or so and the pose changes.
Is this a problem of setup? But there doesn't seem to be a parameter that influences this.
Originally posted by ct2034 on ROS Answers with karma: 862 on 2015-02-01
Comment by Miquel Massot on 2015-02-11:
Are your images rectified?
For a kinect I would recommend you use fovis VO. With it you will take advantage of the depth image and get better results than only with a monocular visual odometer.
Originally posted by Miquel Massot with karma: 1471 on 2015-02-06
