I have subscribed to /camera/depth/points to get the PointCloud2 data from kinect. When I try to print the PointCloud2 data alone leaving out the headers, height and width etc i get a pool of garbage values. How do i print the 'data' field alone.? I am able to get the output without any garbage if i print the entire msg.
Here is my code.
#!/usr/bin/env python
import roslib
import rospy
from sensor_msgs.msg import PointCloud2
def callback(msg):
    print len((data.data))
    print msg.data
    listener.unregister()
def kinect_depth():
    rospy.init_node('kinect_depth', anonymous=True)
    global listener
    listener = rospy.Subscriber("/camera/depth/points", PointCloud2, callback)
    rospy.spin()
if __name__=='__main__':
    kinect_depth()
Thanks in advance.
Originally posted by gaussian on ROS Answers with karma: 88 on 2015-02-01
The PointCloud2 is packed into a format that is not automatically unpacked. sensor_msgs/point_cloud2.py can help you unpack the data (though it is a bit slow).
Alternatively, if you just want depth, and not x,y,z points, you could subscribe to the depth image and use cv_bridge to get the data.
Originally posted by Dan Lazewatsky with karma: 9115 on 2015-02-01
Comment by gaussian on 2015-02-01:
Thanks for your reply. I will look into it. I want the x,y,z data without converting the pointcloud2 into .pcd file. Is it possible to get that?
Comment by Dan Lazewatsky on 2015-02-01:
Yes, that's what the functions in point_cloud2.py do.
Comment by gaussian on 2015-02-02:
@Dan Lazewatsky If I use the latter method of converting the depthimage into grayscale image, how can I convert that into depth in some unit. As the grayscale value in the image are relative to largest depth. Am i right? Is there any const conversion factor between grayscale value and deptin in 'm'?
Comment by Dan Lazewatsky on 2015-02-02:
Using openni_camera at least, depth images contain uint16 depths in mm.
