I am trying to install pointcloud_to_laserscan package in ROS Indigo running in Ubuntu 14.04. When I add the source from git repo and catkin_make I get the following error.
root@ramkumar-Inspiron-7720:/home/ramkumar/catkinws# catkin_make
Base path: /home/ramkumar/catkinws
Source space: /home/ramkumar/catkinws/src
Build space: /home/ramkumar/catkinws/build
Devel space: /home/ramkumar/catkinws/devel
Install space: /home/ramkumar/catkinws/install
#### Running command: "cmake /home/ramkumar/catkinws/src -DCATKIN_DEVEL_PREFIX=/home/ramkumar/catkinws/devel -DCMAKE_INSTALL_PREFIX=/home/ramkumar/catkinws/install -G Unix Makefiles" in "/home/ramkumar/catkinws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/ramkumar/catkinws/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/indigo
-- This workspace overlays: /opt/ros/indigo
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/ramkumar/catkinws/build/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.6.11
-- BUILD_SHARED_LIBS is on
-- ~~  traversing 7 packages in topological order:
-- ~~  - p3dx_control
-- ~~  - depthimage_to_laserscan
-- ~~  - pointcloud_to_laserscan
-- ~~  - openni_tracker
-- ~~  - rosaria
-- ~~  - p3dx_description
-- ~~  - p3dx_gazebo
-- +++ processing catkin package: 'p3dx_control'
-- ==> add_subdirectory(ua_ros_p3dx/p3dx_control)
-- +++ processing catkin package: 'depthimage_to_laserscan'
-- ==> add_subdirectory(depthimage_to_laserscan-indigo-devel)
-- +++ processing catkin package: 'pointcloud_to_laserscan'
-- ==> add_subdirectory(pointcloud_to_laserscan)
-- Using these message generators: gencpp;genlisp;genpy
CMake Error at /opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:75 (find_package):
Could not find a package configuration file provided by "tf2_sensor_msgs"
with any of the following names:
tf2_sensor_msgsConfig.cmake
tf2_sensor_msgs-config.cmake
Add the installation prefix of "tf2_sensor_msgs" to CMAKE_PREFIX_PATH or
set "tf2_sensor_msgs_DIR" to a directory containing one of the above files.
If "tf2_sensor_msgs" provides a separate development package or SDK, be
sure it has been installed.
pointcloud_to_laserscan/CMakeLists.txt:4 (find_package)
See also "/home/ramkumar/catkinws/build/CMakeFiles/CMakeOutput.log".
See also "/home/ramkumar/catkinws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
Please help
Originally posted by gaussian on ROS Answers with karma: 88 on 2015-01-29
As always: what have you tried yourself, and what didn't work?
The error message is particularly clear: catkin (or actually cmake) cannot find the package tf2_sensor_msgs. Do you have that package installed?
It is always a good idea to first do a rosdep check --from-paths src --ignore-src from your /path/to/catkin_ws directory before trying to compile packages you just cloned from some vcs repository.
Also: it would seem pointcloud_to_laserscan has been released into Indigo (see the wiki page). I would recommend to install the Debians instead of building from source, unless you have a specific reason.
Originally posted by gvdhoorn with karma: 86574 on 2015-01-29
Comment by gaussian on 2015-01-29:
Thanks. I have done that and got it working. forgot to close the post. sorry.
What do u mean by installing the Debians. I am a newbie. please help.
Comment by gvdhoorn on 2015-01-30:
Just install the binary distribution? sudo apt-get install ros-indigo-pointcloud-to-laserscan?
Comment by gaussian on 2015-01-30:
I solved that problem. it requires the PointCloud2 data to be published in /cloud_in topic and that node will publish the laserscan data in /scan. after i publish the pointcloud data i get the resultant scan data full of only 'Inf' and hence no plot in rviz. Any idea @gvdhoom Thanks in advance!
Any new questions should go in new questions. Don't hijack this one (even if it is your own). If question answered, please click the check mark.
