Hi,
I'm releasing a package with bloom for the first time and I'd like to run a prerelease test.
I'm following this tutorial: http://wiki.ros.org/bloom/Tutorials/FirstTimeRelease and everything works fine until I arrive at Step 4 here: http://wiki.ros.org/bloom/Tutorials/PrereleaseTest#bloom.2BAC8-Tutorials.2BAC8-PrereleaseTest.2BAC8-indigo.Prepare_the_release
Now, obviously the pre-release site doesn't know my repository, yet, because there is not entry in the release.yaml file at all. However, if I do open the pull-request to get that in there, I'd release it without ever testing. Am I missing some step in between or what is the correct way to proceed?
As a side-note I've entered bloom-release multiple times and it's bumped the version each time. Is there any way to reset that, so I don't have unnecessary versions in between? I'm OK with resetting the release repo as that's new anyways.
Originally posted by dornhege on ROS Answers with karma: 31395 on 2015-01-28
The prerelease website can test your package based on data from three places:
  • The repository and branch listed in your source entry in the distribution.yaml on ros/rosdistro
  • This is the devel option.
  • The release repository and the "release" branch for each package.
  • Since this is a branch it will be updated after you push from bloom, but before you submit the pull request.
  • This is the latest option.
  • The latest released version of your package.
  • This is the x.y.z option, where x, y, and z are numbers for you package's most recent released version.
Now the question is, should you do a prerelease? The prerelease job does something that no other job does, it downloads, builds, and tests released packages which depend on your packages. This is really awesome if you are releasing a new version of a package which has already been released, but it is strictly less useful when you are releasing a package for the first time, since that means there are no released packages which can depend on you yet.
On the first release into a ROS distribution, I would recommend either just not doing a prerelease or doing the binary build test locally, see: http://wiki.ros.org/bloom/Tutorials/PrereleaseTest#bloom.2BAC8-Tutorials.2BAC8-PrereleaseTest.2BAC8-indigo.Perform_the_pre-release_locally
For Jade we plan to roll out a new tool which allows you to do pre-releases locally and with more control. This should make it easier to debug pre-releases and faster to run them since you don't have to wait on our farm which gets pretty backed up on pre-releases.
Originally posted by William with karma: 17335 on 2015-01-28
