Hi,
the compilation is OK, but when I launch the programm and press SPACE bar to update, the programm crashes. There is the image of the error below.
Originally posted by leobber on ROS Answers with karma: 15 on 2015-01-19
I'm not an expert at this, but i hope it helps. Have you checked if you're using SIFTGPU detector in case of not using a GPU? Something like this was happening with me and it was because of that, check your rgbdslam.launch.
Originally posted by Phelipe with karma: 74 on 2015-01-20
Comment by Felix Endres on 2015-01-26:
if that's the case, try to set ORB instead of SIFTGPU in your launchfile
