Hello,
I am trying to implement SLAM using rgbdslam. But when i run the command "roslaunch rgbdslam kinect+rgbdslam.launch" from the wiki page "http://wiki.ros.org/rgbdslam?distro=fuerte", i get the following error. I appreciate any help.
WARNING: [/home/morteza/fuerte_workspace/sandbox/rgbdslam_freiburg/rgbdslam/launch/kinect+rgbdslam.launch] unknown attribute 'no_launch-prefix'
[ERROR] [1419625375.970080106]: Tried to advertise a service that is already advertised in this node [/camera/depth_registered/image_rect_raw/compressedDepth/set_parameters] [ERROR] [1419625375.977429410]: Tried to advertise a service that is already advertised in this node [/camera/depth_registered/image_rect_raw/compressed/set_parameters] [ERROR] [1419625375.988461110]: Tried to advertise a service that is already advertised in this node [/camera/depth_registered/image_rect_raw/theora/set_parameters]
REQUIRED process [rgbdslam-23] has died! process has died [pid 5256, exit code 127, cmd /home/morteza/fuerte_workspace/sandbox/rgbdslam_freiburg/rgbdslam/bin/rgbdslam __name:=rgbdslam __log:=/home/morteza/.ros/log/f811358e-8d3c-11e4-abdb-08edb96bfa77/rgbdslam-23.log]. log file: /home/morteza/.ros/log/f811358e-8d3c-11e4-abdb-08edb96bfa77/rgbdslam-23*.log Initiating shutdown!
Originally posted by Morteza on ROS Answers with karma: 9 on 2014-12-26
Comment by Morteza on 2014-12-27:
Also, when i try to start the openni nodes and RGBDSLAM separately with the commands 'roslaunch openni_launch openni.launch' and 'rosrun rgbdslam rgbdslam', I get the following error.
/home/morteza/fuerte_workspace/sandbox/rgbdslam_freiburg/rgbdslam/bin/rgbdslam: error while loading shared libraries: libsiftgpu.so: cannot open shared object file: No such file or directory
Hi,
the first ERROR messages are unrelated, they are from the camera driver and AFAIK can be safely ignored.
The message starting with REQUIRED more or less says that rgbdslam crashed. The message in your comment hints towards a missing library. Apparently you need to build the siftgpu library, which should have been done by rosmake. To do it manually, run make in rgbdslam/external/siftgpu/linux and copy the created external/siftgpu/linux/bin/libsiftgpu.so to a directory searched by the linker (try rgbdslam/lib or check the linker command line with make VERBOSE=1 for -L/some/dir parameters).
Also note that there's a much better version available for ROS hydro on github
Originally posted by Felix Endres with karma: 6468 on 2015-01-12
Comment by Morteza on 2015-01-13:
Thank you for your response. I downloaded the hydro version and it works well. In fuerte i did what you said but when i ran make, although the libsiftgpu.so was made, i got error.
Comment by Felix Endres on 2015-01-14:
Ok, I guess that's fine then.
