I have installed ros indigo on ubuntu 14.04.1 following the instructions. But met a problem, details like below:
bash: /opt/ros/indigo/setup.bash: No such file or directory
Then i check the directory of "/opt", found that it is empty, like below:
ros@ubuntu:/opt$ ls -al
total 8
drwxr-xr-x  2 root root 4096 Dec 21 13:40 .
drwxr-xr-x 23 root root 4096 Dec 21 13:35 ..
ros@ubuntu:/opt$
And when i executed the commands(like following), it gave the same error.
echo "source /opt/ros/indigo/setup.bash" >> ~/.bashrc
source ~/.bashrc
Could someone help me? Thanks a lot!
Originally posted by fireice on ROS Answers with karma: 1 on 2014-12-21
Comment by Wolf on 2014-12-22:
Did anything fail during sudo apt-get install ros-hydro-destop-full ?
Comment by gvdhoorn on 2014-12-22:
Also: which "instructions"?
Comment by fireice on 2014-12-22:
@Wolf I used sudo apptitude install ros-indigo-desktop-full instead of sudo apt-get.
But there were no error.
@gvdhoorn following this one: http://wiki.ros.org/indigo/Installation/Ubuntu
Comment by krishna890227 on 2016-07-04:
Hi friends I am also suffering from same problems in my raspberryPI 3B. My operating system is NOOBS, but i found command line instruction for Wheezy or Jessie. How can i solve these problems.
Comment by 130s on 2016-07-04:
@krishna890227 please open a new question, with sufficient info of your situation.
You simply didn't install anything. Since you are going to use Ubuntu 14.04.1 it is for you the best option to simply install from the repository. Here you have the procedure. Just pay attention to every code of line, don't forget any instructions. Later on you can configure your environment accordingly. The first 2-3 times I had problems too. The first problem to understand,why and what you need to run ROS. But after that you can fast realize that's quite normal and it won't be a problem anymore :P
Originally posted by Andromeda with karma: 893 on 2014-12-22
thanks! i will try again.
