Hi, I wrote an global planner for my turtlebot. But when I tried to source my .bashrc, only one setup.bash can work. When I source ~/turtlebot/devel/setup.bash, I can use simulator or navigation . But I need to load my own planner plugin, so I source ~/catkin_ws/devel/setup.bash, Then I can see the plugin. But I can not use anything about turtlebot now. It seems that source ~/turtlebot/devel/setup.bash is cancelled. If I source ~/turtlebot/devel/setup.bash again, I can use turtlebot but I can not see my plugin, source ~/catkin_ws/devel/setup.bashstopped working. Can anybody help me with this? For convenience, I usually put all such things in .bashrc file. But it seems that only one setup.bash can work at a time.
Originally posted by Tixiao on ROS Answers with karma: 130 on 2014-12-18
Comment by AlexR on 2014-12-18:
I would suggest copying the whole turtlebot package into your catin_ws/src and only sourcing catin_ws/devel/setup.bash will not produce any conflicts. I have been tweaking a lot of turtlebot packages this way and had no issues so far. Try it.
Comment by BennyRe on 2014-12-19:
Especially take care of section 3.3 of the tutorial @Thomas D linked.
Comment by Murilo F. M. on 2014-12-22:
Also, this question and this question are closely related to your problem.
This sounds like issues with workspace overlaying (http://wiki.ros.org/catkin/Tutorials/workspace_overlaying). You should be able to do what you want, I'm just not sure exactly how without diving into it more. Hopefully that link gets you in the right direction.
Originally posted by Thomas D with karma: 4347 on 2014-12-18
