I could convert RGB messages in to picture but says that the "[32FC1] is not a color format. but [mono8] is. The conversion does not make sense". Is there anything else i should be doing?
my code
import roslib
from matplotlib import pyplot as plt
roslib.load_manifest('beginner_tutorials')
import sys
import rospy
import cv2
from sensor_msgs.msg import Image
from cv_bridge import CvBridge, CvBridgeError
import numpy as np
i=0
np.set_printoptions(threshold='nan')
def callback(data):
 try:
        cv_image = CvBridge().imgmsg_to_cv2(data, "32FC1")
 except CvBridgeError, e:
        print e
 global i
 cv_image1 = np.array(cv_image, dtype=np.float)
 cv2.normalize(cv_image1, cv_image1, 0, 1, cv2.NORM_MINMAX)
 cv_image1=cv_image1*2**16
 cv2.imwrite("im"+str(i)+".jpg")
     i+=1
def video():
rospy.init_node('video', anonymous=True)
im=rospy.Subscriber('/camera/depth_registered/image_rect', Image, callback)
rospy.spin()
if __name__ == '__main__':
   video()
Originally posted by shravan on ROS Answers with karma: 3 on 2014-12-17
Your question: Is it possible to convert depth messages as Ipl image using CvBridge? Yes, definitely! But: for the rest of your question: It depends! ;)
In the first place the resulting IplImage (or better to use cv::Mat) will have the same color space as the incoming image, i. e. if you call cv_bridge::toCvShare(msg) or toCVCopy without encoding a published "32FC1" image will result in an "32FC1" (32bit floating point, one channel). For some color spaces cv_bridge can handle the color transformation, i. e. your can call cv_bridge::toCvShare(msg, your_encoding ) where your encoding must not necessarily be the encoding of the original image message ( e. g. rgb8 <---> bgr8 ); However, this does not work for all encoding combinations!
Apparently, if you get an error it does not work for the transformation you desired! Therefore, you should read your the image first without specifying an encoding (cv_bridge::toCvShare(msg)) and that do your desired transformation yourself. The image callback of rqt_image_view gives a good example of how to do this, see: https://github.com/ros-visualization/rqt_common_plugins/blob/groovy-devel/rqt_image_view/src/rqt_image_view/image_view.cpp#L265
Commenting on your edit: I am not familiar with opencv python but I commented your code where it seams unclear:
        cv_image = CvBridge().imgmsg_to_cv2(data, "16UC1")  ## was your image not 32 float?
                                                            ## this means 16 unsigned integer
        print e
 global i
 cv_image1 = np.array(cv_image, dtype=np.float)  ## type float again?
                                                 ## up there you converted to unsigned int 16!
Originally posted by Wolf with karma: 7555 on 2014-12-17
Comment by shravan on 2014-12-17:
@wolf Thanks for the suggestion.It helped me to convert depth messages to opencv images but after saving it shows me a black image. When i Googled ,it told me that 32FC1 images cannot be stored and I am not sure how to convert it into a 8bit or 16 bit data to store it. Is it possible to do it
And I used Opencv python for this conversion
Comment by Wolf on 2014-12-18:
Does rqt_image_view properly scale your images? you cannot directly convert 32 bit floating point image to 8 Bit images; you have to scale/quantify in some kind of way so you can see what is going on...
Comment by shravan on 2014-12-18:
@wolf i have added my code. When I try this out I get an image but it is distorted . I guess Opencv does not take 16 bit images. Is there any possibility write images of 16bit type
@wolf . Sorry for that, it is my mistake .I have corrected it .Now have a look
