If you are just trying to compare your pose estimate to a Gazebo ground truth, I believe you should be able to directly compare your pose in the map frame with your Gazebo model state pose. In other words, don't worry about any transforms or your odom frame pose; I would just compare the output of amcl
(the amcl_pose
PoseWithCovarianceStamped message) with the Gazebo ground truth.
EDIT in response to question edit:
First, if you haven't yet, read over REP-105.
map and odom are both "world" frames. For most applications, when you start running, your pose in both the map frame and the odom frame are (0, 0) with a heading of 0 (simplifying to 2D for this example). In other words, the frames are completely aligned. As you move through the world, your pose in odom frame will suffer from drift, owing to the fact that it doesn't (or shouldn't) have any global position corrections included in its estimate. However, it is accurate for short distances, so it's useful for local planning and path execution. The position in the map frame will not drift, and should be much more accurate over time, as you have absolute position corrections coming from things like GPS, or in the case of amcl
, from measurements of the world itself through LIDAR. However, these corrections can cause your map frame position estimate to "jump," making it difficult to use for planning. Imagine if your robot was moving towards a goal, and then its position estimate suddenly shifted by one meter. It may have to suddenly change its direction for no apparent reason.
In a perfect world, your position in the map
frame would always be identical to your position in the odom
frame.
For Gazebo, there is no estimation going on, as Gazebo knows exactly where your robot is. They call their world frame world. As it is ground truth, it is more accurate than either your map or odom frames. However, you can ignore the names of the frames, as they are irrelevant for what you are trying to do. All you need to do is literally compare your poses in all three. In other words, all three frames (world, map, and odom) represent the same thing, but to varying degrees of accuracy. So:
Open up a terminal and enter rostopic echo /model_states
. Unfortunately, I think the model_states
topic is going to report the pose of all models in the scene, so you'll have to find the one that refers to your model. Now open up a new terminal and enter rostopic echo /amcl_pose
(assuming that's what your amcl
instance is producing and you haven't remapped the topic). Now open up a third terminal and enter rostopic echo /odom
(or whatever the name of your EKF output topic is). Now just look at the pose values for X, Y, and Z and the orientation. If they're close for a long time, then amcl
is working for you.
Originally posted by Tom Moore with karma: 13689 on 2014-12-17
Post score: 6
Comment by arenillas on 2014-12-17:
I didn't know about that topic. Thank you.
I will update the question with my new doubts.
