I've being trying to get ROS + turtlebot (Hydro) installed on my mac (running osx 10.10). ROS installed happily. However I am running into a few issues with compiling the turtlebot specific packages from source (http://wiki.ros.org/turtlebot/Tutorials/hydro/Installation).
When I run:
rosdep install --from-paths src -i -y
I get the following errors:
ERROR: the following packages/stacks could not have their rosdep keys resolved
to system dependencies:
kobuki_ftdi: No definition of [ftdi-eeprom] for OS [osx]
kobuki_qtestsuite: No definition of [pyqt4-dev-tools] for OS [osx]
As expected, continuing on with catkin-make doesn't work out too well.
How would I go about solving/getting arounds this? (I don't mind if its not a full blown answer, would at least like to be pointed in the right direction)
Also, just for reference, a somewhat similar question was asked quite a while back without that much success: http://answers.ros.org/question/89831/install-turtelbot-simulator-on-mac-os/
Originally posted by genericsoup on ROS Answers with karma: 45 on 2014-12-04
The error message you're getting from rosdep indicates that it can't find two packages that it depends on: ftdi-eeprom and pyqt4-dev-tools. Both of these packages have pages on the ubuntu package site: ftdi-eeprom and pyqt4-dev-tools, which should give you links back to the original package website and sources.
You'll need to figure out if these packages are available through homebrew or pip; if they are, you can simply install them and add the appropriate rosdep keys, as the previous answer suggests. (See this answer for instructions on how to set up local rosdep keys so that you can test them before submitting them to rosdistro)
If you can't find these packages in homebrew or pip, you'll have to look into building and installing them from source on OSX. If you can get them manually installed, rosdep probably won't be able to detect that they're installed, but you should still be able to run catkin_make and build the turtlebot packages against them.
Originally posted by ahendrix with karma: 47576 on 2014-12-04
Comment by William on 2014-12-04:
For local testing you can also use the --skip-key to rosdep if you are confident that the dependency has been resolved.
Comment by genericsoup on 2014-12-06:
Thanks for the pointers guys, will have a go at this over the coming days.
