I'm developing my fligth controller board on Tiva Launchpad for quadcoper and while calibrating PID I discovered an unexpected behaviour: sometimes quadcopter seems to experience random angle errors. While trying to investigate it, I've figured out that my code if fairly trying to compensate tham, as soon as they appear - but do not cause them. Even more - i've discovered that such behaviour appears only when two (or more) motors are adjusted, while one motor system shows pretty good stabilisation.
Here is code for PMW output for different motors:
torque[0] = (int16_t)(+ angles_correction.pitch - angles_correction.roll) + torque_set;
torque[1] = (int16_t)(+ angles_correction.pitch + angles_correction.roll) + torque_set;
torque[2] = (int16_t)(- angles_correction.pitch + angles_correction.roll) + torque_set;
torque[3] = (int16_t)(- angles_correction.pitch - angles_correction.roll) + torque_set;
and here is recorded angles for system with one motor and two motors:
To be sure that it's not the algorithm problem, while recording this angles only Integral part of PID was non-zero, so angles were not even stabilised.
My question is - could esc noise each other (in my quad they are quite close to each other - just few sentimeters away) to cause such behaviour? Thanks a lot!
