Let's suppose node A subscribe the topic published by node B. Node A do many caculatations for the subscribed data, it will take a lot of time. However, node B publish topic too fast and assume we can not change the publish rate. So many data published by node B can not be subscribed on time. These data will be lost.
So is there any method to buffer the subscribed topic?
Originally posted by somebodyus on ROS Answers with karma: 113 on 2014-11-27
One easy way is to increase queue size of subscriber.
ros::Subscriber sub = n.subscribe("topic_name", 1000, subscriber_callback);  //  queue size is 1000
Originally posted by bvbdort with karma: 3034 on 2014-11-27
Comment by somebodyus on 2014-12-01:
How to do that using command? I can not modify the source file.
Comment by bvbdort on 2014-12-02:
You should change in source code. I dont think its possible from command line.
