Hi,
I am trying to setup ros on OSX 10.10. I'm following the installation instructions given here: http://wiki.ros.org/indigo/Installation/OSX/Homebrew/Source. While resolving the dependencies using this command:
rosdep install --from-paths src --ignore-src --rosdistro indigo -y
I get an ld: symbol(s) not found for architecture x86_64 error while installing collada-dom and opencv. This I guess is associated with the default stdlib for clang being libc++ instead of libstdc++.
So I tried to install the dependencies of collada-dom with libstdc++. I was able to install Boost successfully but am unable to figure out how to install pcre with libstdc++.
Also for opencv I installed it using libstdc++ using the formula provided here, but this is just a keg-only formula. Even though I symlinked myself, rosdep isn't detecting this version.
Any help is much appreciated. Has anyone been able to get it working on OSX 10.10?
Originally posted by chintak on ROS Answers with karma: 11 on 2014-11-26
Comment by William on 2014-12-02:
I haven't had time to upgrade to 10.10 myself, so unfortunately I can't reproduce any of these issues yet.
Comment by chintak on 2014-12-02:
Hmm. Are you on Mavericks? Can I compile against 10.8 SDK on Yosemite/Mavericks?
I don't think it is as easy as changing os x sdk versions. I think the pcre problem is an issue with the provided stdlib and compiler. But without more details I doubt anyone can help without reproducing it. As for rosdep you can just skip the opencv key if you know it is installed.
Originally posted by William with karma: 17335 on 2014-12-02
