Hi, I successfully calibrated my camera (rosrun uvc_cam_node works well) but when I launch ar_pose I get error that my camera isn't calibrated:
[ERROR] [1416872150.188997696]: Rectified topic '/camera/image_rect' requested but camera publishing '/camera/camera_info' is uncalibrated
Please help me and dispel my doubts:
  1. Compare two rosnode lists: Are they the same? /uvc_camera node = /camera/uvc_camera_node
  2. uvc_camera_node is a node which transmit video from camera to ROS and /camera/uvc_camera_node is a node which ar_pose use to get video to recognize maker/tag?
  3. Compare topic lists: /camera_info, /image_raw and /camera/camera_info, /camera/image_raw should I remap something in launch?
  4. Why in launch we set parameters and after It there is command 'find' which load parameters from file? is there any sense?
DETAILS: when I ran: uvc_camera I get:
przemek@przem:~/tum_simulator_ws/src/ar_tools/ar_pose/launch$ rosrun uvc_camera uvc_camera_node
[ INFO] [1416870421.617654535]: using default calibration URL
[ INFO] [1416870421.617885710]: camera calibration URL: file:///home/przemek/.ros/camera_info/camera.yaml
opening /dev/video0
pixfmt 0 = 'YUYV' desc = 'YUV 4:2:2 (YUYV)'
  discrete: 640x480:   1/30 1/15
  discrete: 352x288:   1/30 1/15
  discrete: 320x240:   1/30 1/15
  discrete: 176x144:   1/30 1/15
  discrete: 160x120:   1/30 1/15
  discrete: 1280x1024:   2/15 1/5
  int (Brightness, 0, id = 980900): -10 to 10 (1)
  int (Contrast, 0, id = 980901): 0 to 20 (1)
  int (Saturation, 0, id = 980902): 0 to 10 (1)
  int (Gamma, 0, id = 980910): 100 to 200 (1)
  int (Gain, 0, id = 980913): 32 to 48 (1)
  menu (Power Line Frequency, 0, id = 980918): 0 to 2 (1)
    0: Disabled
    1: 50 Hz
    2: 60 Hz
  int (Sharpness, 0, id = 98091b): 0 to 10 (1)
select timeout in grab
and everything seems to be ok...
Rosnode and rostopic list:
przemek@przem:/opt/ros/indigo/share/uvc_camera$ rosnode list
/rosout
/uvc_camera
przemek@przem:/opt/ros/indigo/share/uvc_camera$ rostopic list
/camera_info
/image_raw
When I run ar_single_pose I get error:
process[camera/uvc_camera_node-4]: started with pid [22299]
process[ar_pose-5]: started with pid [22314]
[ INFO] [1416872056.747424013]: camera calibration URL: file:///opt/ros/indigo/share/uvc_camera/camera_calibration.yaml
[ INFO] [1416872057.006555638]: Starting ArSinglePublisher
[ INFO] [1416872057.008427734]:     Publish transforms: 1
[ INFO] [1416872057.013649211]:     Publish visual markers: 1
[ INFO] [1416872057.015248159]:     Threshold: 100
[ INFO] [1416872057.016890548]:     Marker Width: 152.4
[ INFO] [1416872057.019849023]:     Reverse Transform: 0
[ INFO] [1416872057.023319574]:     Marker frame: ar_marker
[ INFO] [1416872057.027037854]:     Use history: 1
[ INFO] [1416872057.046105711]:     Marker Center: (0.0,0.0)
[ INFO] [1416872057.046718919]: Subscribing to info topic
opening /dev/video0
    0: Disabled
    1: 50 Hz
    2: 60 Hz
[ INFO] [1416872059.116906053]: *** Camera Parameter ***
SIZE = 320, 240
Distortion factor = 0.000000 0.000000 0.000000 1.000000
0.00000 0.00000 0.00000 0.00000
[ INFO] [1416872059.117126682]: Loading pattern
[ INFO] [1416872059.118051380]: Subscribing to image topic
[ERROR] [1416872060.024344493]: Rectified topic '/camera/image_rect' requested but camera publishing '/camera/camera_info' is uncalibrated
[ERROR] [1416872090.108035723]: Rectified topic '/camera/image_rect' requested but camera publishing '/camera/camera_info' is uncalibrated
[ERROR] [1416872120.186654733]: Rectified topic '/camera/image_rect' requested but camera publishing '/camera/camera_info' is uncalibrated
and now: rosnode and rostopic list:
/ar_pose
/camera/image_proc
/camera/camera_info
/camera/image_raw
Originally posted by green96 on ROS Answers with karma: 115 on 2014-11-24
Have you really calibrated your camera using the camera calibrator?
http://wiki.ros.org/camera_calibration
Some camera drivers may publish an empty uncalibrated camera_info along with the image, which seems to be the case as your calib matrix contains all zeros and the distortion factor is the default 0.000000 0.000000 0.000000 1.000000
Originally posted by Wolf with karma: 7555 on 2014-11-25
Comment by green96 on 2014-11-25:
EDIT / I found solution!
Yes, but I was doing it in wrong way. Because commit button didn't work, I manually copied file from calibration tar to appropriate localisation.
How to repair commit button in calibration: http://tinyurl.com/nksyrdm
I calibrated it again and commited setting to driver.
