ihave this error
user@ubuntu:~$ sudo apt-get install ros-indigo-desktop-full
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ros-indigo-desktop-full : Depends: ros-indigo-desktop but it is not going to be installed
Depends: ros-indigo-perception but it is not going to be installed
Depends: ros-indigo-simulators but it is not going to be installed
E: Unable to correct problems, you have held broken packages
Originally posted by ksmksam on ROS Answers with karma: 13 on 2014-11-24
Comment by Tom Moore on 2014-11-24:
I think we'll need some more information. What version of Ubuntu are you running?
Comment by ksmksam on 2014-11-24:
14.04
ok this is
Try installing only ros-indigo-desktop
, and see if anything fails. If so, try installing one of the packages that failed. Repeat this and eventually you'll get a more informative error from whatever the offending package is.
ros-indigo-desktop: command not found
sorry we still have problem
[sudo] password for user:
Comment by ahendrix on 2014-11-24:
Do you have the universe and metaverse repositories enabled?
Comment by ksmksam on 2014-11-25:
ian new user with upuntu so can you help how ican checked
sorry vertion 12.04 LTS trusty
tom moore
