I am trying to use slam gmapping on a robulab robot with no success. One of the problems is that I have the laser topic working apparently fine (in RViz the points cloud changes as I move the robot), but when I run static_transform_publisher
from /base_link
to /laser
it stop working (in RViz it looks frozen).
I run it like this:
- Run robot's driver node
- Publishes:
/scan
(laserScan) and/pose
(poseStamped) - Subscribes:
/command_velocity
Run odometry node: Basically consumes
/pose
and provides/odom
(Odometry). I know there is a misconception here because the robot's driver node should provide/odom
. I will fix, but I think the problem is not here.Run slam gmapping like this:
rosrun gmapping slam_gmapping tf_static:=tf
At this point I get the following frames chain: /map
-> /odom
-> /base_link
as you can see here and this is the node graph.
- In RViz I check laser's points cloud by manually putting "laser" on fixed frame, and after added LaserScan display and I can see it and it get updated when I move the robot.
I also have this error on terminal running it:
[ WARN] [1415365252.295826588]: MessageFilter [target=odom ]: Dropped 100.00% of messages so far. Please turn the [ros.gmapping.message_notifier] rosconsole logger to DEBUG for more information
In some blog posts I've seen that laser frame is published through a static transform through
rosrun tf static_transform_publisher 0 0 0 0 0 0 /base_link /laser 50.
Then, in RViz the image freezes even trying clicking "Reset" button. On the LaserScan section, in "Status" it appears this error:
"Transform [sender=unknown_publisher] Message removed because it is too old (frame=[/laser],stamp=[1415289470.551291000])"
But also, in the terminal where I run RViz, this is warning message:
[ WARN] [1415365456.608259629]: MessageFilter [target=map ]: The majority of dropped messages were due to messages growing older than the TF cache time. The last message's timestamp was: 1415361856,504979, and the last frame_id was: /odom
At this point this is the node graph and frames.
- Finally, when I kill the process of static_transform_publisher, it gets back to behaviour before.
What could be happening here?
Originally posted by Pablo Estefó on ROS Answers with karma: 3 on 2014-11-12
