Hello, I want to install ROS groovy from source on ubuntu armel 12.04 according to this page http://wiki.ros.org/groovy/Installation/Source. I have download the ros-comm to /ros_catkin_ws/src. Than run :
$rosdep install --from-paths src --ignore-src --rosdistro groovy -yr
I get the following error
 executing command [sudo apt-get install -y python-rospkg]
Reading package lists... Done
Building dependency tree
E: Unable to locate package python-rospkg
executing command [sudo apt-get install -y python-catkin-pkg]
E: Unable to locate package python-catkin-pkg
executing command [sudo apt-get install -y sbcl]
Package sbcl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  sbcl-source sbcl-doc
E: Package 'sbcl' has no installation candidate
executing command [sudo apt-get install -y python-rosdep]
E: Unable to locate package python-rosdep
ERROR: the following rosdeps failed to install
  apt: command [sudo apt-get install -y python-rospkg] failed
  apt: command [sudo apt-get install -y python-catkin-pkg] failed
  apt: command [sudo apt-get install -y sbcl] failed
  apt: command [sudo apt-get install -y python-rosdep] failed
  apt: Failed to detect successful installation of [python-rospkg]
  apt: Failed to detect successful installation of [python-catkin-pkg]
  apt: Failed to detect successful installation of [sbcl]
  apt: Failed to detect successful installation of [python-rosdep]
In fact, I have successfully installed rospkg , catkin-pkg and rosdep. So,I install them again.
$sudo pip install rospkg catkin-pkg rosdep
I got the following:
Requirement already satisfied (use --upgrade to upgrade): rospkg in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied (use --upgrade to upgrade): catkin-pkg in /usr/local/lib/python2.7/dist-packs
Requirement already satisfied (use --upgrade to upgrade): rosdep in /usr/local/lib/python2.7/dist-packages
Please help me to solve this problem. thank you very much.
Originally posted by Alice63 on ROS Answers with karma: 63 on 2014-11-11
rosdep cannot detect the installation of packages through pip. You can ignore any errors for packages that are installed through pip (python-rospkg, python-rosdep and python-catkin-pkg).
There is no version of sbcl available for the armel version of Ubuntu, so you'll have to go through your ROS source tree and remove the packages that depend on sbcl. (probably roslisp and friends). You'll also want to remove any other packages that actually use sbcl, and edit the package.xml for ros_comm to remove the dependency on sbcl.
PS: I'm still going to recommend that you install an armhf version of Ubuntu instead of trying to make things work on armel. The armel packages perform poorly; you won't be able to run any interesting packages like navigation or use the OpenNI/Kinect drivers.
Originally posted by ahendrix with karma: 47576 on 2014-11-11
Comment by Alice63 on 2014-11-13:
Thank you ahendrix .Now the roscore can run succesfully on arm when I remove the roslisp. At the same time,I am finding an armhf version of Ubuntu,too.I want to try the boths way.
