I'm attemping to copy that message over the topic visualization_msgs::MarkerArray with a function like this:
void myclass::incomingPoints( const visualization_msgs::MarkerArray &waypoints )
    goals.reserve( waypoints->markers.size() );
    copy( waypoints->markers.begin(), waypoints->markers.end(), back_inserter( goals ) );
where:
std::vector<visualization_msgs::Marker> goals;
But trying to compile I get the error that says: .begin(), .size(), and .end() are not defined in the
error: base operand of ‘->’ has non-pointer type ‘const MarkerArray {aka const visualization_msgs::MarkerArray_std::allocator<void
}’ goals.reserve( waypoints->markers.size() );
and that's ok, because they are in the class vector defined. But how can I copy that array?
Regards
Originally posted by Andromeda on ROS Answers with karma: 893 on 2014-11-09
Ok, I can answer myself.
I discoevered the using such function signature:
    goals.reserve( waypoints.markers.size() );    <---- Note the point!!!
    copy( waypoints.markers.begin(), waypoints.markers.end(), back_inserter( goals ) );   <---- Note the point!!!
it compiles
And changing the signature to:
void myclass::incomingPoints( const visualization_msgs::MarkerArray::ConstPtr &waypoints )
    goals.reserve( waypoints->markers.size() );    <---- Note the arrow
    copy( waypoints->markers.begin(), waypoints->markers.end(), back_inserter( goals ) );   <---- Note the arrow
even works.
Function signature and called method must also match.
Originally posted by Andromeda with karma: 893 on 2014-11-09
