Hello,
I am trying to use gmapping package for building a map.
My tf tree is complete: map --> odom --> robot/base_footprint --> robot /base_link --> robot/laser
map --> odom is broadcast by /slam_gmapping and odom --> robot/base_footprint is broadcast by /ekf_localization
At the beginning I was getting the following warning message:
MessageFilter [target=/odom ]: Dropped 100.00% of messages so far. Please turn the [ros.gmapping.message_notifier] rosconsole logger to DEBUG for more information
I set the DEBUG mode in rqt, and I got the following message:
 MessageFilter [target=odom ]: Added message in frame laser at time 1414977417.595, count now 5
using this therad. I set rosparam set use_sim_time true, and the warning message disappeared, but the DEBUG mode is still showing the message above.
Nothing is published to /map topic.
Laser is published to robot/scan
I am not sure if I have to set the frame id for my laser which is robot/laser or not. gmapping does not seem to have such a parameter, but I have set
 <param name="base_frame" value="robot/base_footprint"/>
 <param name="odom_frame" value="odom"/>
I have also set in my launch file:
<arg name="scan_topic" default="robot/scan" />
<remap from="scan" to="$(arg scan_topic)"/>
Any thoughts?
Originally posted by ROSCMBOT on ROS Answers with karma: 651 on 2014-11-02
gmapping's default topic for scandata is "scan". you are using instead "robot/scan". so just remap the topic in your launchfile (i assume you use one):
<remap from="scan" to="robot/scan" />
or in your terminal:
rosrun gmapping slam_gmapping scan:=robot/scan
Originally posted by lebowski with karma: 146 on 2014-11-03
Comment by ROSCMBOT on 2014-11-03:
I'm actually remapping the scan topic in my launch file.
Comment by lebowski on 2014-11-03:
please open rviz and
  1. set "fixed frame" to "odom"
  2. add display type tf
  3. add laserscan -> set topic to "robot/scan"
lets see if any errors/warnings appear
