Hey guys,
so far i have been using gazebo to simulate my algorithms (and then simulating the results in Gazebo), but now i have a real robot available and i wanted to know how i can load the urdf model (so i can see it in "rviz" and profit of the links to "tf ") without using the spawn robot launch file:
<node name="robot_spawner" pkg="gazebo_ros" type="spawn_model" args="$(optenv ROBOT_INITIAL_POSE) -unpause -urdf -param robot_description -model mobile_base"/>
of gazebo_ros (because this launch script also launches gazebo).
Any suggestion would be very appreciated
Marcus
Originally posted by Marcus on ROS Answers with karma: 164 on 2014-10-31
That launch command assumes that the urdf has been written to the parameter robot_description. In Rviz, add a RobotModel to the displays with the topic robot_description (should be the default).
Originally posted by David Lu with karma: 10932 on 2014-10-31
Comment by Marcus on 2014-11-02:
Thanks David, that worked perfectly.
