Here is how to connect to the Katana via USB. These instructions are tested on our Katana 450 6M90a with an internal control board (i.e., a "base" to mount the arm). You are indeed correct that when you connect the Katana via USB, it acts as a USB network device.
Connect the arm via USB and switch it on.
Since the arm doesn't have a DHCP server, you need to configure the network manually. Open up NetworkManager and create a new connection for the USB network adapter interface:
- IP address: 192.168.1.* , where * is anything in the range [2-255], e.g. 192.168.1.77
- network mask: 255.255.255.0
- no gateway (0.0.0.0)
The arm should now respond to ping 192.168.1.1
. If it doesn't, don't continue and fix this problem first.
Make sure that the katana parameters are properly set: use_serial = false
and ip = "192.168.1.1"
(see the katana wiki page ). These are the defaults, but e.g. katana_300_6m180.launch
changes these defaults.
If you still have problems, please edit your question and include the following information:
- What Katana arm do you have, exactly? Is it e.g. a Katana 300 6M180? Does it have an internal/external control board or none?
- What ROS version are you using?
- What's your
katana_driver
branch? Did you make any local changes?
- What launch files are you starting?
Answers to your reply:
Error when launching katana.launch: which first says "trying to connect to katana (serial port:/dev/ttyS0) and then says cannot get/set attributes on '/dev/ttyS0'.
Edit the katana_300_6m180.launch
file and remove the line where it says use_serial
(or set the param to false).
Error when launching katana_300_6m180.launch: says the parameter katana_type was not set!
You shouldn't launch that file directly; instead, use katana.launch
, then this error doesn't occur. That file includes katana_300_6m180.launch
fatal error: armadillo: No such file or directory
Just do the following:
sudo rosdep init
rosdep update
rosdep install katana_driver
If that doesn't work, just do the following directly:
sudo apt-get install libarmadillo-dev
Originally posted by Martin Günther with karma: 11816 on 2014-10-24
Comment by tufail on 2014-11-04:
Everything worked fine. Thanks.
I didn't have to set the use_serial
param to false as the katana I have is 400 6M180 (not 300). So for I have been setting the KATANA_TYPE
environment variable to katana_300_6m180
which was wrong.
I installed the `libarmadillo-dev' and rosmake worked too.
Comment by João Almeida on 2015-10-08:
Hi Martin,
I have exactly this problem. My computer doesn't have a serial port so I'm using a Prolific Serial to USB converter to connect to the Katana.
However I didn't understand exactly how to set up the network interface for the USB port. Could you please try to explain me exactly how to do it?
Comment by Martin Günther on 2015-10-09:
I guess if you're using a serial to USB converter, it should show up as a serial port, right? So you shouldn't set up any network interface, but set use_serial = true.
Comment by João Almeida on 2015-10-13:
Thank you Martin! We fixed the problem by creating a symbolic link between the '/dev/ttys0/ and the '/dev/ttyUSB0'.
