While doing the tutorial, i get the following error when i run catkin_make
-- ==> add_subdirectory(helloworld) CMake Error at helloworld/CMakeLists.txt:11 (rosserial_generate_ros_lib): Unknown CMake command "rosserial_generate_ros_lib". -- Configuring incomplete, errors occurred! Invoking "cmake" failed
What could be the problem?
I use ubuntu 12.04 with Hydro
Originally posted by Robbie025 on ROS Answers with karma: 1 on 2014-10-21
I suggest you to check whether the content of ros-hydro-rosserial-arduino includes arduino-cmake files. I believe rosserial_generate_* CMake functions for arduino are defined in these files.
If file mentioned in comment is absent, try to add it in the place where CMake can find it. Maybe it will work.
Originally posted by kp with karma: 26 on 2014-10-22
Comment by kp on 2014-10-22:
Would be helpful if you include link to the exact tutorial with which you have a problem.
https://github.com/ros-drivers/rosserial/blob/indigo-devel/rosserial_client/cmake/rosserial_client-extras.cmake
This file should be present in your system, and CMake should be able to find it.
I tried to find it in hydro-devel branch, but seems it's not there. So maybe tutorial is for Indigo.
Comment by pando85 on 2014-10-24:
I tried it in groovey and I coudn't compile it, but with indigo all go well.
