Hello,
I know that this question might be asked before, but I did not find the final solution for it. Here is the question:
I want to write a node that subscribe for data from a topic then publish these data to another topic. So, mainly I want a publisher and subscriber in the same node. So What I did so far is the following:
#include "ros/ros.h"
#include <geometry_msgs/Twist.h>
#include "pctx_control/Control.h"
#include "std_msgs/String.h"
#include "pctx_control/pctx.h"
#include <sstream>
pctx_control::Control controlmsg ;
void function_callback (const geometry_msgs::Twist &msg)
controlmsg.ch = 0 ;
controlmsg.values[0] = msg.linear.x;
controlmsg.values[1] = msg.linear.y;
controlmsg.values[2] = msg.linear.z;
std::cout << "d1"<<controlmsg.values[0] << std::endl ;
std::cout << "d2" <<controlmsg.values[1]<< std::endl ;
std::cout << "d3" <<controlmsg.values[2]<< std::endl ;
 ros::init(argc, argv, "my_node");
  ros::NodeHandle n;
 ros::Publisher pub = n.advertise<pctx_control::Control>("topic2", 100);
  ros::Subscriber sub = n.subscribe("topic1", 1000, function_callback);
 ros::Rate loop_rate(10);
 ros::spinOnce();
 int count = 0;
 while (ros::ok())
    pub.publish(controlmsg);
  ros::spin();
  loop_rate.sleep();
return 0;
I want to save data that I want to publish in a "custom msg" pctx_control::Control type;
This msg has the following format:
int32 ch
int32 value
int16[] values
Originally posted by RSA_kustar on ROS Answers with karma: 275 on 2014-10-19
If you make the publisher global, you can publish as soon as the message is received in function_callback(). Then the while() loop can be replaced with just ros::spin();
#include <sstream>
ros::Publisher pub;
pctx_control::Control controlmsg;
  controlmsg.ch = 0;
  controlmsg.values.resize(3);
  std::cout << "d1" << controlmsg.values[0] << std::endl;
  std::cout << "d2" << controlmsg.values[1] << std::endl;
  std::cout << "d3" << controlmsg.values[2] << std::endl;
  ros::NodeHandle n;
  // Handle ROS callbacks until shutdown
  ros::spin();
  return 0;
Edit: Changed vector indexing to push_back()
Edit: Changed vector indexing back to brackets, and reinitialize with resize() every iteration per comment from @dornhege
Originally posted by kmhallen with karma: 1416 on 2014-10-19
Comment by RSA_kustar on 2014-10-20:
@kmhallen
I did what you said, I got an error said Segmentation fault (core dumped) .
I was tracing the problem it give me this error after this line of code
I maigh be filling this one in the wrong way.. what should I do ?? can you check the message type, please.
I knew how to fill it using push_pack().. Thanks for your help
Comment by dornhege on 2014-10-20:
Careful, this code is buggy. You must clear the values in the controlmsg every time before publishing or mvoe that to a local variable.
