I cannot get Kinect (PC edition) to be detected with ROS (indigo) freenect_launch. Ubuntu (using grinch kernel) packaged freenect_glview does give me Kinect image and depth information, ROS glview does not find device.
Bus 002 Device 009: ID 045e:02bf Microsoft Corp.
Bus 002 Device 008: ID 045e:02be Microsoft Corp.
Bus 002 Device 005: ID 045e:02c2 Microsoft Corp.
Thanks for hints.
Originally posted by cc_smart on ROS Answers with karma: 3 on 2014-10-16
It looks like the version of libfreenect that is included in ROS is currently too old to support the Kinect4Windows.
There is an open ticket about this.
Originally posted by ahendrix with karma: 47576 on 2014-10-20
Comment by cc_smart on 2014-10-20:
Thanks for reply ! Unfortunately neither of these worked for me, but if I understand correctly, Kinect does work for you in the Jetson ? I'm wondering if the USB id values do not match "expectations" of the library coming with ROS ? What Kinect edition / USB ID values do you use / see ? Thanks again
Comment by ahendrix on 2014-10-20:
Yes, I have an original Kinect.
If the note regarding freenect version and recommendation for bugtracker ticket was pulled out, I believe I can give that the "correct answer" mark. I believe this can added as bugtracker link: Ticket
