I want to extract depth image from .bag file just like the tutorial. But when I run $ roslaunch export.launch , the error occurred as below:
SUMMARY
PARAMETERS
 * /rosdistro
 * /rosversion
NODES
    extract (image_view/extract_images)
    rosbag (rosbag/play)
core service [/rosout] found
process[rosbag-1]: started with pid [9394]
process[extract-2]: started with pid [9405]
[ INFO] [1413444044.771603283]: Initialized sec per frame to 0.100000
 [ERROR] [1413444046.270973202]: Client [/extract] wants topic /camera/depth/disparity to have datatype/md5sum [sensor_msgs/Image/060021388200f6f0f447d0fcd9c64743], but our version has [stereo_msgs/DisparityImage/04a177815f75271039fa21f16acad8c9]. Dropping connection.
pls help me to resolve it.Thanks.
Originally posted by hffgodspeed on ROS Answers with karma: 1 on 2014-10-16
That script you are running is designed for color images not depth images. You'll need to modify it a little bit to support the different data type.
Originally posted by tfoote with karma: 58457 on 2014-10-18
Comment by hffgodspeed on 2014-10-20:
Could you please tell me how to modify it? Thank you.
