After a successful catkin_make, I made sure to source devel/setup.bash inside the catkin workspace and ran roscore. The output of echo "$ROS_PACKAGE_PATH" is "/home/alex/kinect_bench/src:/opt/ros/hydro/share:/opt/ros/hydro/stacks".
I get his warning from catkin_make:
In file included from /usr/include/c++/4.6/backward/strstream:52:0,
             from /usr/include/vtk-5.8/vtkIOStream.h:112,
             from /usr/include/vtk-5.8/vtkSystemIncludes.h:40,
             from /usr/include/vtk-5.8/vtkIndent.h:24,
             from /usr/include/vtk-5.8/vtkObjectBase.h:43,
             from /usr/include/vtk-5.8/vtkSmartPointerBase.h:26,
             from /usr/include/vtk-5.8/vtkSmartPointer.h:23,
             from /usr/include/pcl-1.7/pcl/visualization/point_cloud_geometry_handlers.h:48,
             from /usr/include/pcl-1.7/pcl/visualization/point_cloud_handlers.h:41,
             from /usr/include/pcl-1.7/pcl/visualization/common/actor_map.h:40,
             from /usr/include/pcl-1.7/pcl/visualization/pcl_visualizer.h:47,
             from /usr/include/pcl-1.7/pcl/visualization/cloud_viewer.h:39,
             from /home/alex/kinect_bench/src/grabber/src/openni_grabber.cpp:2:
/usr/include/c++/4.6/backward/backward_warning.h:33:2: warning: #warning This file includes at least one deprecated or antiquated header which may be removed without further notice at a future date. Please use a non-deprecated interface with equivalent functionality instead. For a listing of replacement headers and interfaces, consult the file backward_warning.h. To disable this warning use -Wno-deprecated. [-Wcpp]
also, when I run roswtf the output is:
Loaded plugin tf.tfwtf No package or stack in context
================================================================================ Static checks summary:
Found 1 error(s).
ERROR Not all paths in PYTHONPATH [/home/alex/kinect_bench/devel/lib/python2.7/dist-packages:/opt/ros/hydro/lib/python2.7/dist-packages] point to a directory:   * /home/alex/kinect_bench/devel/lib/python2.7/dist-packages
================================================================================ Beginning tests of your ROS graph. These may take awhile... analyzing graph... ... done analyzing graph running graph rules... ... done running graph rules
Online checks summary:
Found 1 warning(s). Warnings are things that may be just fine, but are sometimes at fault
WARNING The following node subscriptions are unconnected:  * /rosout:    * /rosout
my CMakeLists:
project(grabber)
  pcl_conversions
  pcl_msgs
  pcl_ros
  roscpp
  sensor_msgs
  std_msgs
find_package(Boost REQUIRED COMPONENTS system)
catkin_package(
  INCLUDE_DIRS include
  LIBRARIES grabber
  CATKIN_DEPENDS pcl_conversions pcl_msgs pcl_ros roscpp sensor_msgs std_msgs
  DEPENDS system_lib
include_directories(
  ${catkin_INCLUDE_DIRS}
  ${PCL_LIBRARY_DIRS}
  ${PCL_INCLUDE_DIRS}
#add_library(grabber
#  src/${PROJECT_NAME}/grabber.cpp
# target_link_libraries(grabber_node
#   ${catkin_LIBRARIES}
link_directories(${PCL_LIBRARY_DIRS})
add_definitions(${PCL_DEFINITIONS})
add_executable (grabber src/openni_grabber.cpp)
target_link_libraries (grabber ${PCL_LIBRARIES} ${catkin_LIBRARIES})
my package.xml;
<?xml version="1.0"?>
<package>
  <name>grabber</name>
  <version>0.0.0</version>
  <description>The grabber package</description>
  <maintainer email="[email protected]">alex</maintainer>
  <license>TODO</license>
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>pcl_conversions</build_depend>
  <build_depend>pcl_msgs</build_depend>
  <build_depend>pcl_ros</build_depend>
  <build_depend>roscpp</build_depend>
  <build_depend>sensor_msgs</build_depend>
  <build_depend>std_msgs</build_depend>
  <run_depend>pcl_conversions</run_depend>
  <run_depend>pcl_msgs</run_depend>
  <run_depend>pcl_ros</run_depend>
  <run_depend>roscpp</run_depend>
  <run_depend>sensor_msgs</run_depend>
  <run_depend>std_msgs</run_depend>
 </package>
Thanks for any help
Originally posted by kinect_guy on ROS Answers with karma: 38 on 2014-10-14
Comment by ahendrix on 2014-10-14:
What is the exact command that is failing? is it rosrun grabber grabber ?
Comment by kinect_guy on 2014-10-14:
the failing command is rosrun grabber openni_grabber openni_grabber is the file located at ~/kinect_bench/src/grabber/src/openni_grabber.cpp
The add_executable(grabber src/openni_grabber.cpp) line in your CMakeLists is creating an executable named grabber. Therefore, the correct command to run your program is:
Originally posted by ahendrix with karma: 47576 on 2014-10-15
