Hey there!
I already asked this over at the Trossen Robotics Forum but did not get a reply yet. Maybe someone here can give me a hint at what might be wrong with my XV-11 Lidar Setup.
I bought the laser scanner from Ebay and am trying to get it to work in ROS.
What I have done so far:
  • Connected the Lidar to ROS Indigo running Ubuntu in Virtualbox on a Windows Machine.
  • For the power to the motor I am using a 3V regulator that gets its power form USB (5V).
  • The sensor is powered by an Arduino with 3.3V for now.
  • Instead of the Sparkfun FTDI board I am using a standard RS-232 to USB Adapter that is getting its data from the Lidard's Tx. The adapter gets accepted by Ubuntu. Dmesg shows:
    usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
  • Running
    rostopic echo /scan
I get this:
header: seq: 34 stamp: secs: 1413106818 nsecs: 470585788 frame_id: neato_laser angle_min: 0.0 angle_max: 6.28318548203 angle_increment: 0.0174532923847 time_increment: 0.00059940997744 scan_time: 0.0 range_min: 0.0599999986589 range_max: 5.0 ranges: [0.25600001215934753, 8.192000389099121, 4.928999900817871, 13.229000091552734, 13.300999641418457, 13.274999618530273, 10.946999549865723, 0.37700000405311584, 14.380999565124512, 15.883000373840332, 15.381999969482422, 0.25600001215934753, 8.960000038146973, 6.848999977111816, 13.114999771118164, 13.0649995803833, 13.126999855041504, 13.109000205993652, 0.36899998784065247, 14.380999565124512, 15.883000373840332, 15.378000259399414, 0.5120000243186951, 1.2799999713897705, 6.880000114440918, 13.14900016784668, 10.869000434875488, 9.96500015258789, 10.836999893188477, 0.37599998712539673, 14.348999977111816, 15.873000144958496, 15.847999572753906, 16.128000259399414, 11.008000373840332, 6.90500020980835, 11.003000259399414, 10.888999938964844, 10.954999923706055, 4.479000091552734, 0.33799999952316284, 15.279000282287598, 14.972999572753906, 7.293000221252441, 0.23399999737739563, 8.019000053405762, 8.29699993133545, 15.732999801635742, 15.833000183105469, 7.519999980926514, 11.776000022888184, 8.960000038146973, 6.888999938964844, 11.795000076293945, 13.74899959564209, 13.708999633789062, 11.914999961853027, 0.4320000112056732, 11.229000091552734, 16.277000427246094, 16.277000427246094, 9.472000122070312, 8.704000473022461, 3.884999990463257, 16.381999969482422, 16.381999969482422, 16.381999969482422, 16.381999969482422, 8.295999526977539, 15.189000129699707, 16.277000427246094, 13.991999626159668, 9.472000122070312, 0.0, 3.628000020980835, 16.381999969482422, 16.381999969482422, 16.381999969482422, 16.381999969482422, 7.690999984741211, 15.189000129699707, 16.277000427246094, 15.187999725341797, 9.472000122070312, 7.935999870300293, 3.627000093460083, 16.381999969482422, 16.381999969482422, 16.381999969482422, 16.381999969482422, 8.399999618530273, 15.189000129699707, 16.277000427246094, 13.991999626159668, 9.472000122070312, 7.679999828338623, 3.625999927520752, 16.381999969482422, 16.381999969482422, 16.381999969482422, 16.381999969482422, 8.295999526977539, 15.189000129699707, 16.277000427246094, 13.991999626159668, 9.472000122070312, 7.423999786376953, 13.097000122070312, 16.381999969482422, 16.381999969482422, 16.381999969482422, 16.381999969482422, 8.406000137329102, 15.189000129699707, 16.277000427246094, 16.37700080871582, 15.871999740600586, 11.520000457763672, 14.026000022888184, 16.381999969482422, 16.381999969482422, 16.381999969482422, 16.381999969482422, 0.43700000643730164, 16.35700035095215, 16.37700080871582, 16.356000900268555, 15.871999740600586, 4.0960001945495605, 14.001999855041504, 16.381999969482422, 16.381999969482422, 16.381999969482422, 16.381999969482422, 0.43700000643730164, 16.047000885009766, 16.37700080871582, 16.327999114990234, 15.871999740600586, 8.192000389099121,
and so on...
So there seems to be data coming in.
But then here's my problem. In RVIZ the data looks like noise and it seems like the Laser is detecting itself. It shows a circular thing right in the middle although the unit is sitting on a shelf with rectangular walls around it.
Here is a screenshot of both my settings and the RVIZ point cloud.
rviz http://oi58.tinypic.com/2rolv6f.jpg
Any ideas what could be the problem? Might this be a problem due to the difference between RS232 and TTL? Is my conversion going wrong? But the why would I get a valid header?
In the meantime I switched the power for the sensor itself (not the motor) to 5V after confirming that it can take it. Did not change anything though...
Thanks in advance!
Originally posted by tinytron on ROS Answers with karma: 45 on 2014-10-14
The header is generated on the computer side, not the lidar, so it's quite possible that your data is corrupt even though the header looks correct. TTL and RS-232 use different voltages and different polarities, so that's probably causing problems.
I would start by finding a proper USB to TTL serial converter. It doesn't have to be the specific Sparkfun model, but it should definitely be a 5V level and non-inverted (RS-232 is inverted).
Originally posted by ahendrix with karma: 47576 on 2014-10-15
