Hi, i tried to install package tum_simulator but I found one problem. When I try to run simulator:
roslaunch cvg_sim_test 3boxes_room.launch
i get:
[cvg_sim_test] is not a package or launch file name
I have ROS fuerte and installed gazebo 1.6, rviz.
I was adding step by step packages: ardrone_autonomy package, joy_node and ardrone_joystick packages, tum_simulator package. I used 'rosmake' and I didn't get any error.
My workspace looks:
przemek@przem:~/fuerte_workspace$ ls ardrone_autonomy sandbox setup.sh simulator_gazebo visualization ardrone_helpers setup.bash setup.zsh tum_simulator
When I call echo $ROS_PACKAGE_PATH I get:
/home/przemek/fuerte_workspace/simulator_gazebo:/home/przemek/fuerte_workspace/sandbox:/opt/ros/fuerte/stacks:/opt/ros/fuerte/share:/opt/ros/fuerte/share/ros:/home/przemek/fuerte_workspace/ardrone_autonomy:/home/przemek/fuerte_workspace/ardrone_helpers:/home/przemek/fuerte_workspace/ardrone_helpers:/home/przemek/fuerte_workspace/tum_simulator
there is almost everything apart from rviz.
Please help me.
Originally posted by green96 on ROS Answers with karma: 115 on 2014-10-14
It looks like the tum_simulator repository has a 'fuerte' branch which includes the cvg_sim_test package. Have you tried that version?
Originally posted by ahendrix with karma: 47576 on 2014-10-16
Comment by green96 on 2014-10-16:
I was doing exactly what is on http://wiki.ros.org/tum_simulator. So I cloned from git this link:
https://github.com/tum-vision/tum_simulator.git
now I see that it has branch master and below we can find info that it is for hydro.
So if i have ros-fuerte I should clone from this link?
https://github.com/tum-vision/tum_simulator/tree/fuerte
(Sorry for double comment but there is limit of characters..)
Comment by ahendrix on 2014-10-16:
No. You already have a copy of the repository on your machine; you just need to check out the 'fuerte' branch. Try: roscd tum_simulator and git checkout fuerte
Thank you so much for your help, unfortunately before you wrote your answer I had reinstalled my ROS to Indigo version and just now successfully run simulator. :) So I can't check it, but conclusion is to clone from git using parameter -b, for example: -b indigo
