I'm going through the ROS packages for a generic package that will take raw IMU 9DOF readings and perhaps use a Kalman filter to fuse data from the Accelerometer, Gyroscope, and Magnometer. So far I've only found the imu_filter_madgwick package. However, it has been difficult to install with catkin. As a newbie to the ROS system I found this surprising.
Is there a generic solution for IMU filtering in ROS?
Thank you in advance. I would appreciate any guidance in this matter.
Originally posted by alainh on ROS Answers with karma: 43 on 2014-10-11
Are you using the hydro branch? It works fine with catkin.
Originally posted by tonybaltovski with karma: 2549 on 2014-10-11
Comment by alainh on 2014-10-11:
You're absolutely right. I forgot to switch branches. Thank you! To continue the discussion, however, is this the only raw data IMU solution?
Comment by tonybaltovski on 2014-10-11:
robot_localization uses the IMU data in an EKF.
Comment by alainh on 2014-10-24:
Follow up: While I got most of the package dependencies to build, it trips up on the boost library from tf with errors. I made a separate question found here: http://answers.ros.org/question/194856/error-with-boost-while-building-tf-package-in-catkin-ws/
