Hello ros-users,
I have strange issue with tf-transforms. I use laser_geometry::LaserProjection to project laser scans to point clouds, but I assume the problem is related to tf. The code-snippet is from the scan callback function.
if(!gTfListener->waitForTransform(scan->header.frame_id,
                              "camera",
                              scan->header.stamp,
                              ros::Duration(2.0),
                              ros::Duration(0.01),
                              &error_msg))
    ROS_WARN("Warning 1: %s", error_msg.c_str());
    return;
try
    gProjector->transformLaserScanToPointCloud("camera", *scan, cloud, *gTfListener);
}catch(tf::TransformException e)
    ROS_WARN("Warning 2: %s", e.what());
    return;
After a few seconds of running, Warning 2 is raised on the console for like 1 out of 4 scans with this error message:
Warning 2: Lookup would require extrapolation into the future. Requested time 1412757571.359567610 but the latest data is at time 1412757571.357117891, when looking up transform from frame [laser_link] to frame [camera]
How can this happen, after waitForTransform obviously succeeded (returned true)?
Thanks in advance, Sebastian
Originally posted by Sebastian Kasperski on ROS Answers with karma: 1658 on 2014-10-08
Comment by GuillaumeB on 2014-10-08:
you could try to set a very long time for the duration (the time it should wait) . My computer was slow and it solved the problem
Comment by Sebastian Kasperski on 2014-10-08:
Increasing the wait time did not change the behaviour, as waitForTransform already returned true (e.g. didn't timeout)
My assumption about tf was wrong, the solution was indeed related to laser_geometry. As described here, the Projector uses start and end time of the scan and therefore asks for a timestamp in the future.
So to wait long enough, the call to waitForTransform should be:
       "camera",
        scan->header.stamp + ros::Duration().fromSec(scan->ranges.size()*scan->time_increment),
        ros::Duration(2.0),
        &error_msg))
Originally posted by Sebastian Kasperski with karma: 1658 on 2014-10-08
