I am trying to run the ASUS Xtion pro on eletric Ubuntu 10.04. Long story short, it was working initially and then all my openni drivers got wiped, so reinstalled the drivers using the wiki.
Now when I try to run rosrun openni_launch openni.launch the device can be detected but says it is not a matching device as below. There is also no camera feed when using rosrun image_view image_view image:=/camera/rgb/image_color
[ INFO] [1412296948.638187940]: Number devices connected: 1
[ INFO] [1412296948.640244380]: 1. device on bus 001:08 is a Xtion Pro (601) from ASUS (1d27) with serial id ''
[ INFO] [1412296948.645037848]: Searching for device with index = 1
[ INFO] [1412296952.665433343]: No matching device found.... waiting for devices. Reason: openni_wrapper::OpenNIDevice::OpenNIDevice(xn::Context&, const xn::NodeInfo&, const xn::NodeInfo&, const xn::NodeInfo&) @ /tmp/buildd/ros-electric-openni-kinect-0.3.6/debian/ros-electric-openni-kinect/opt/ros/electric/stacks/openni_kinect/openni_camera/src/openni_device.cpp @ 99 : creating depth generator failed. Reason: Got a timeout while waiting for a network command to complete!
Does anyone know why this is occurring or what the error reason is?
Originally posted by zemark on ROS Answers with karma: 18 on 2014-10-02
Couple of links for you to try
http://www.pcl-users.org/libusb-OpenNI-permission-denied-Kinect-amp-Ubuntu-td3720915.html
http://www.pcl-users.org/IOException-starting-up-openni-Grabber-td4025713.html
Cheers
Mark
Originally posted by MarkyMark2012 with karma: 1834 on 2014-10-03
Manged to solve my own problem. Followed this tutorial for Xtion Pro not being connected or matched and worked perfectly
http://robotica.unileon.es/mediawiki/index.php/PCL/OpenNI_troubleshooting#No_device_found_.2F_No_devices_connected
Originally posted by zemark with karma: 18 on 2014-10-04
